ULINK ME is no longer recognized after installing V4.22, with 4.20 it works..
anybody run into the same issue?
Werner
I just upgrade from V4.21 to V4.22. My ULINK ME work as before.
It does work now with V4.22. Sometimes after stop debugging, the device is not recognized anymore. It says in the Keil IDE, "internal DLL error" when I try to use the FLASH function. I did not observe this behaviour before.. Maybe it was a coincidence that re-activating V4.20 instead 4.22 caused it to work normal again.
