Hi All,
I have an array struct's with const data in flash memory defined as follows
const SOD_ObjectDictionaryEntry* pSDOEntryTable = SDOEntryTable;
This works fine ...
I want to use this array in an external file as follows
extern const SOD_ObjectDictionaryEntry SDOEntryTable[];
Compiling give me following error : error: #513: a value of type "const SOD_ObjectDictionaryEntry *" cannot be assigned to an entity of type "SOD_ObjectDictionaryEntry *".
when I replace it by
extern const SOD_ObjectDictionaryEntry* SDOEntryTable;
I have the same error.
extern SOD_ObjectDictionaryEntry SDOEntryTable[]
the linker gives an error SDOEntryTable not found , witch is normal.
How can I define a pointer to const data external ?
This defines a pointer to SDOEntryTable, not an array. Presumably, SDOEntryTable is an array. You didn't show the definition of SDOEntryTable. Is there a reason why you are defining a pointer instead of using the array identifier directly? So you have two variables: an array and a pointer. Do you want the pointer to be used in multiple source files? If so, declare it in the other files like so:
extern const SOD_ObjectDictionaryEntry* pSDOEntryTable;
The simple rule is this: a declaration without the extern keyword defines a variables (and allocates memory for it), whereas a declaration with the extern keyword simply creates a reference to a variable defined in another file.
Problem solved, thanks. Kind regards
