Circular buffer logical error?
I was going through the sample code i obtained from the keil website for LpC2148 USB .As far as i could make out, the code just echos the contents of a buffer onto the hyperterminal when a keypress is detected.
In the PopfromCIrBuf function, i have encountered a small problem. As i understand it, Bufsize is the amt of data to be read in the cir buf and size = size of location we are writing to. Logically , we should write when bufsize<= size but the code seems to be doing the opposite.
However this code runs correctly. upon modifying bufsize>= size to bufsize <= size and executing, it did not work. i would like to understand this anomaly. Thank you for your attention. the code is as follows .
#include <LPC214x.H>              /* LPC21xx definitions */
#include "type.h"
#include "vcom.h"
#include "usbapi.h"
#define USB_TEXT "\n\r Testing USB NGX's BlueBoard \n\r BlueBoard Revision : 1 \n\r Firmware Version: 1 \n\r For more information on BlueBoard visit ">www.ngxtechnologies.com"
        Funtion Name : test_usb()
        Description  :
        Input        :
        Output       : None
        Note         :
void test_usb(void)
  U8 buffer[] = USB_TEXT;
  while((VCOM_write(sizeof(buffer), buffer)) != sizeof(buffer));
int main (void)
        U8 ch = 0;
        SCS = 3;    //sets port 1 and 0 to fast mode (not compatable with previous LPCs)
        VCOM_init();
        while (1)
            if(get_USB_enumeration_status())
                        if(VCOM_read(sizeof(ch),&ch))
                                test_usb();
VCOM read is
S32 VCOM_read(U16 len,U8 *buf)
  S32 retval=0;
if(get_USB_enumeration_status()) { retval = popFromCirBuf(&in_circular_buf, buf, len);
if( (retval >0) && (retval < len)) { popFromCirBuf(&in_circular_buf, buf, retval); } }
return retval; }
and circlar buffer relevant code is
S32 getCirBufSize(CIR_BUFFER *circular_buf)
  U32 retval= 0 ;
  if ( circular_buf != NULL )
    if ( (circular_buf->readPos <= circular_buf->writePos ) && circular_buf->overflow == 0)
      retval = ( circular_buf->writePos ) - circular_buf->readPos;
    else if ( ( circular_buf->writePos == circular_buf->readPos ) && circular_buf->overflow == 1 )
      retval = circular_buf->size ;
    else
      retval = (circular_buf->size - circular_buf->readPos) + circular_buf->writePos ;
  return retval;
S32 popFromCirBuf(CIR_BUFFER *circular_buf, U8 *buffer, U32 size)
  S32 retval= 0;
  U32 i;
  U32 BufSize;
     BufSize = getCirBufSize (circular_buf);
     if ( BufSize >= size )
        for(i=0;i<size;i++)
          buffer[i] = circular_buf->Buffer [ circular_buf->readPos ];
          if ( circular_buf->readPos+1 == circular_buf->size )
            circular_buf->readPos = 0;
            circular_buf->overflow = 0 ;
          else
            circular_buf->readPos ++ ;
        retval = size ;
    else if(BufSize < size )
      retval = BufSize;
  else
    retval = -1;
  return retval;
