[C51] [BugReport] [Code Reuse] Constant data encoded as DB statements not generated
I think I had found a bug on Keil V8.12,
Does anybody tell me if this bug report will be received by the developers of keil company?
and after checked the release note of Keil V9.02,
I thought the bug may be not fixed on the latest version (V9.02)
Issue analyze:
[Platform]
Device type: Dallas 8032
IDE version: Keil V8.12
Memory Model: Large: variables in XDATA
Code Optimization: Level 8 or above
[Condition] //personal guess :)
1. the same code reuse after "C?LSTKPTR"
2. the same code reuse after "C?LSTKXDATA"
[Result]
The constant data encoded as DB statements following the library function call had been lost!
[Analyze] //personal guess :)
The routines "C?LSTKPTR" and "C?LSTKXDATA" should both generate four "DB 0" in this test function,
but the compiler not only optimized the code reused segment (test8 = 0;) but also cut the DB statement
of first library routines(C?LSTKXDATA)
typedef unsigned char UINT8;
typedef unsigned long UINT32;
static UINT8 test8 = 1;
static UINT32 test32 = 1;
static UINT32 *ptest32 = &test32;
#pragma OT(8, SPEED)  //change to OT(7, SPEED) is OK
static UINT8 TestFunc(void)
    if (test8) {
        if (test32) {
            test32 = 0; //C?LSTKXDATA
            test8 = 0; //code reused
        } else {
            *ptest32 = 0;
            test8 = 1;
    } else {
        *ptest32 = 0; //C?LSTKPTR
    printf("test8: %bx\n", test8);
    return 0;
    11: static UINT8 TestFunc(void)
    12: {
    13:         if (test8) {
C:0x0524    90002F   MOV      DPTR,#0x002F
C:0x0527    E0       MOVX     A,@DPTR
C:0x0528    6029     JZ       C:0553
    14:                 if (test32) {
C:0x052A    90002B   MOV      DPTR,#0x002B
C:0x052D    120368   LCALL    C?LLDXDATA(C:0368)
C:0x0530    EC       MOV      A,R4
C:0x0531    4D       ORL      A,R5
C:0x0532    4E       ORL      A,R6
C:0x0533    4F       ORL      A,R7
C:0x0534    6008     JZ       C:053E
    15:                         test32 = 0;
C:0x0536    90002B   MOV      DPTR,#0x002B
C:0x0539    120374   LCALL    C?LSTKXDATA(C:0374)
    16:                         test8 = 0;
    17:                 } else {
C:0x053C    801E     SJMP     C:055C
    18:                         *ptest32 = 0;
C:0x053E    900028   MOV      DPTR,#0x0028
C:0x0541    1203BF   LCALL    C?PLDXDATA(C:03BF)
C:0x0544    1203A5   LCALL    C?LSTKPTR(C:03A5)
C:0x0547    00       NOP
C:0x0548    00       NOP
C:0x0549    00       NOP
C:0x054A    00       NOP
    19:                         test8 = 1;
C:0x054B    90002F   MOV      DPTR,#0x002F
C:0x054E    7401     MOV      A,#0x01
C:0x0550    F0       MOVX     @DPTR,A
    20:                 }
    21:         } else {
C:0x0551    8012     SJMP     C:0565
    22:                 *ptest32 = 0;
C:0x0553    900028   MOV      DPTR,#0x0028
C:0x0556    1203BF   LCALL    C?PLDXDATA(C:03BF)
C:0x0559    1203A5   LCALL    C?LSTKPTR(C:03A5)
C:0x055C    00       NOP
C:0x055D    00       NOP
C:0x055E    00       NOP
C:0x055F    00       NOP
    23:                 test8 = 0;
C:0x0560    E4       CLR      A
C:0x0561    90002F   MOV      DPTR,#0x002F
C:0x0564    F0       MOVX     @DPTR,A
    24:         }
    25:
    26:         printf("test8: %bx\n", test8);
    27:
C:0x0565    7BFF     MOV      R3,#0xFF
C:0x0567    7A05     MOV      R2,#0x05
C:0x0569    79B2     MOV      R1,#0xB2
C:0x056B    90002F   MOV      DPTR,#0x002F
C:0x056E    E0       MOVX     A,@DPTR
C:0x056F    900003   MOV      DPTR,#0x0003
C:0x0572    F0       MOVX     @DPTR,A
C:0x0573    12006E   LCALL    PRINTF(C:006E)
    28:         return 0;
C:0x0576    7F00     MOV      R7,#PRINTF517?BYTE(0x00)
    29: }
