RTC
Hi all.
I have a problem whit initialize the RTC on lpc2368. I would have an interrupt every 15.6 ms from CISS register. Can someone help me also with sample code?
Thanks too much.
  • Isn't it better that you post your code, and explains what you spected to happen, and what really happens?
  • I've a problem to initialize the Pll block and the Real time clock.
    I would use Fin=32.768Khz Fcco=288Mhz cclk=Fcco/4=72Mhz.
    I read all the datasheet and i write my code but when i download the code, the mcb2300 doesn't work. I don't understand which is the issue.
    PLLCON = 0x00;
            PLLFEED = 0xAA;                 /*FEED SEQUENCE 1*/
            PLLFEED = 0x55;                 /*FEED SEQUENCE 2*/
            CLKSRCSEL = 0x02;               /*RTC CCLK 32.768KHZ*/
            PLLCFG = 0x12254;
            PLLCON = 0x01;                  /*enable PCONE*/
            CCLKCFG = 3;                    /*Fcco/4 --->CCLK=72MHz*/
            VICIntEnable = (1<<12);
            while ((PLLSTAT & 0x04000000) == 0); /*wait until Phase Lock*/
            PLLCON = 0x03;                       /*enable PCONE and PCONC*/
            RTC_ILR = 0x07;                      /*clear flag*/
            RTC_CISS = 0x85;                     /*enable interrupt every 16ms*/
            RTC_CCR = 0x19;
            VICVectAddr13 = (unsigned long)RTC_IRQHandler;  /* Set Interrupt Vector     */
            VICVectCntl13 = 0;                  /* use it for RTC Interrupt */
            VICIntEnable  = (1  << 13);          /* Enable Interrupt         */
  • I haven't checked through all the constants, but consider protecting your feed sequences from interrupts. And have you checked if the 32768Hz crystal is spinning up? "doesn't work" is a very incomplete problem description. It would imply that almost 100% of all cars doesn't work. You leave the car to the mechanic with the description "doesn't work" because you have noticed that the lamp in the gloves compartment doesn't light?
  • "doesn't work" means that when i've downloaded the code into the device, the board MCB2300 doesn't responds in any way. I need to run Flash magic tool to erase the chip.
  • So you only have a serial interface - no debugger?
    How do you know the code doesn't spend 100% of the time in an interrupt handler - that you don't allow us to see?
    Where are the test printouts or the pin wiggling to tell you how far your code gets?
    Exactly what have _you_ done before posting here that the board "doesn't responds in any way"?
