Use od RTX and deep sleep mode
I am struggeling to put my LPC1227 to deep sleep in my project that uses RTX RTOS.
My project without deep-sleep works great. Also another sample project that uses deep sleep (but no RTX) works like a charm (lpc12xx.cmsis.driver.library).
When I tried to combine this two projects, I get unfunctional project. The code for deep sleep is JUST after tha main loop (before OS initializes). Thu uC goes to deep sleep (I can see with multimeter - 30uA), the uC also somehow wakes up (using GPIO_0_0 as an untrrupt - this I can also see on multimeter - 11mA), but the uC hangs now. Looks like some exception occured or the wake-up procedure is not OK.
I can post the code, it this could be helpfull fo someone.
Please help me ande save me another week of my life :)
Best regards, Rok
  • Then there must be something wrong with your wake-up code.
    Typically, RTX only uses one hardware timer. Check that it is restarted.
    Also, make sure other peripherals that you need once woken up are programmed to be configured.
