Does anyone know how to use column mode for editing source code within uVision3 IDE??? I am used to using Jens where I could insert text in a column format defined by the start and stop of the drag of my cursor. I could then right click and insert defined text on all lines simultaneously starting where my cursor orignated to the end of the highlighted segment area in a column format. Can anyone help with this??? I know how to use the Alt key and mouse to highlight text in a column format, but I can find a way to enter text on multiple lines in a column format. This is very annoying.
Keil or I should say Keil ARM does use Eclipse for there DS-5 toolset. Maybe they will move that Eclipse version into the ARM MDK tools in the near future but I doubt that they will change the C51 tools. I don't know that. It's just a thought. Bradford
have you considered making that "open source"?, you might get a beneficial return
I have, actually, but I have to find some time to recreate a project from scratch and document the steps so it's actually useful.
Andrew
CodeWright has that feature but, as far as I know, doesn't have a correesponding un-comment feature.
So you still need the column edit (or, at least, column select & delete) for that...
Anything that has a suitable command-line invokation...
"I can hook Jens into uVision in the same manner as proposed for hooking in Code Wright???"
I don't see why not.
A bit sloppy to add a "comment" but not a "uncomment" command. A column-delete command is hard, always removing a fixed number of characters. A uncomment command would be able to check each individual line and don't destroy a line that doesn't start with //. No problem if the block is 10-20 lines, but if it is 500 lines, it can be easy to miss that there is some code in the middle that wasn't commented away, when marking the block.
Yes - unless I've just missed it?
I guess the intention must've been just to make a block of text into a comment - rather than to enable/disable sections of code...?
"Release documentation of Eclipse 3.5 seems to contradict you on that"
Yes - I was out-of-date on that!
Eclipse now even does what the OP was talking about; viz, you make a "column" selection, then whatever you type gets repeated down the entire column.
See:
stackoverflow.com/.../how-do-i-enable-the-column-selection-mode-in-eclipse
help.eclipse.org/.../index.jsp
"you make a 'column' selection, then whatever you type gets repeated down the entire column"
So, having only just discovered this, I must say that I am rapidly coming to find it very useful indeed!
"there isn't sufficient number of people using it to justify its existence in the ide"
As I suggested earlier, maybe people - like me - have just never come across it before?
In which case, once one has used it, one might find oneself saying, "how did I ever manage without this?!"
"As I suggested earlier, maybe people - like me - have just never come across it before?"
sure. but that still doesn't change the fact that no sufficient number of people are using that feature.
"In which case, once one has used it, one might find oneself saying, "how did I ever manage without this?!""
having tried it, one might have flip'd the other way saying "what a useless feature!" I tend to think the mkt (of software developers) has spoken and I hope that the fact that many IDE oems have not included this feature in this offering speaks something about its usefulness to the mass.
again, that doesn't mean the feature isn't useful or cannot be useful. it only says that the feature isn't useful enough to be included in the standard offering now.
that may change, as more people learn about it - as in your case.
Andy: "I must say" Ashley "one might have"
who has a point?
the fact that many IDE oems of course not, if an "IDE oems" were selling the IDE because of the editor, it would be different. I have seen no IDE where the editor did not stink to high heaven. Thus on my taskbar next to Keil (or IAR or ...) you always see CodeWright.
"I have seen no IDE"
but you have certainly seen the datasheet specification on T0's maximum clock rate, haven't you?
Tasking's IDE is CodeWright!!
"Tasking's IDE is CodeWright!!"
that explains their huge market share.
Wow! I am starting to feel bad for even asking my original question. Obviously, there is no column mode feature, and obviously there is no plan to add one. I will just have to develop a work-around by hooking another editor into the uVision IDE to edit code with which I would be better served using the column mode feature that I like so much.
However, what's up with the bookmarks on the uVision IDE? If I use the "go to next bookmark feature" with bookmarks on multiple files within a project, the button will not take me automatically to the next file. Are there settings for bookmarks somewhere that I don't know that control this feature? How can I use the button to automatically go to the next bookmark placed if that bookmark is located in another file that I have open within my project???
"I will just have to develop a work-around by hooking another editor into the uVision IDE to edit code with which I would be better served using the column mode feature that I like so much."
you don't even need to hook in any external editors (you can but you don't have to): just edit your files in your editor and then switch over to the ide to compile.
