Does anyone know how to use column mode for editing source code within uVision3 IDE??? I am used to using Jens where I could insert text in a column format defined by the start and stop of the drag of my cursor. I could then right click and insert defined text on all lines simultaneously starting where my cursor orignated to the end of the highlighted segment area in a column format. Can anyone help with this??? I know how to use the Alt key and mouse to highlight text in a column format, but I can find a way to enter text on multiple lines in a column format. This is very annoying.
Alt + drag
http://www.keil.com/support/man/docs/uv4/uv4_ui_seltext.htm
Oops - sorry, I missed that!
But that is the extent of uVision's "column editing" - it does not do what you're asking.
In fact, I wasn't previously aware of any editor that does!
Thank you for the reply, but I am not talking about just selecting text. I want to insert text in a similar format. However, I would like to define the location of the column to start on, then drag to the line where I want to stop at. Then I would like to somehow insert text at this defined location on all lines within the drag highlighted area starting from where the cursor began and stopped.
Oh, alright. Thank you for the help. Yes, this feature is available in Jens and I think Ultra-Edit has it as well. I am unfortunately stuck using this software package. This news is a huge drag to me. Thanks again!
Which software package?
If you mean uVision, note that there is no reason why you have to use the uVision editor - you can edit your files with any editor you choose, and just use uVision for the build & debug.
You could even set up items on the uVision 'Tools' menu to open a file selected in the uVision Project view in your external editor...
I've done this before with CodeWright.
No, I just mean that I am constrained by the product I am working on. I know that you can do a bunch of extra goofing around to edit files outside of the system and import them back into the project, but this defeats the purpose of the package in one concept: project,editor,compiler,linker, and hex converter all in one. Now you have to go outside to get the features that you want to you. It would be nice for one if a company took into consideration all of the editing features that are used by 99% of the software programming community and design the IDE editing around that. Work-arounds are always possible, but convenience is priceless!
1) What "import back"?
2) No integrated environment will ever be able to match the features of any set of stand-alone tools. A swiss army knife will never match the individual tools.
3) I'm not so sure about 99% of the software programming community in regards to column editing.
Are you sure you know what you're talking about?
And what evidence do you have that your particular feature of choice is actually among those 99%?
That set aside, no, that thing would not be nice. It would be huge to the point of being unusable, particularly for newbies.
For starters, it's quite a waste of manpower if every compiler vendor tries to match that goal on their own. The world doesn't need dozens of different implementations of the complete, all-features-covered, perfect IDE. It needs only one --- and it only took about 20 years for the community to realize that. Eclipse seems to be well on the way to eventually end this waste of effort.
"goofing around to edit files outside of the system and import them back into the project"
There is no "gofing around" - you just open the files in the normal manner in the editor(s) of your choice. Simples. Facilities are available to make that more convenient, if you wish.
There is also no "import back into the project" - uVision (unlike Eclipse) just references the files directly on the hardware. So it make no difference whatsoever whether edits are made with the internal editor, or an external tool.
"this defeats the purpose of the package in one concept"
True, but that is, in practice, an unachievable goal.
If there were one single editor which did everything that everybody wants in the way that everyone likes - well, we'd all be using it, wouldn't we?!
As it is, we all have our own preferences - so no "integrated" product can ever completely please all of the people all of the.
I mostly use the uVision internal editor, simply for the convenience. Sometimes, CodeWright has a specific feature that makes a specific task so much easier, that it's worth separately running-up CodeWright for it. Sometimes there's a task that's easier in Word!
I've found exactly the same with every IDE that I've ever used - including Embarcadero RAD Studio (Delphi/C++ Builder), MS Visual Studio, and Eclipse. This has nothing specifically to do with uVision.
"editing features that are used by 99% of the software programming community"
As I said, I was not previously aware of any editor that offered the feature you describe - let alone used it!
"convenience is priceless"
But the trouble with making such a "do-everything" tool is that the number of configuration options required to please everyone's taste would be so vast as to be unworkable. I think Eclipse epitomises this!
I disagree!
Eclipse seems to me to be a perfect illustration that "It would be huge to the point of being unusable"
Eclipse is so versatile and so configurable that, it seems to me, it's (almost) impossible for any non-specialist to understand!
Building an Eclipse-based IDE seems to need about as much development effort as building a proprietary IDE!
And, when things go awry, there's the doubts as to whether the problem is specific to the particular Eclipse implementation (for the implementor to fix), or part of the Framework (for the Eclipse community to fix).
Oh, and Eclipse does not do any form of column editing - it doesn't even do what uVision does! So, when I'm using an Eclipse-based IDE, I still switch to CodeWright when I want to do column editing!
"It would be nice for one if a company took into consideration all of the editing features that are used by 99% of the software programming community"
that's precisely what the ide does not offer the column editing mode you are looking for: 99% of the software programming community does not use it.
that doesn't mean that nobody uses it. just that there isn't sufficient number of people using it to justify its existence in the ide.
I don't know the actual number, but the consensus here certainly does seem to be that it is not a "mainstream" or "widely-used" feature.
"there isn't sufficient number of people using it to justify its existence in the ide"
It could actually be that it's a sufficiently esoteric feature that the uVision developers hadn't even heard of it - let alone made any specific decision about whether or not to implement it!
I think uVision has many much more pressing deficiencies that ought to be addressed before this one! And these are things that really are common in other tools!
You'll note I offered Eclipse as an example to support my assertion that the world has too many bad IDEs already, and could benefit from concentrating that effort some. I never claimed it was lightweight.
Eclipse is indeed huge. Don't even bother trying it in eanest on less than 1 GB. But it offers a lot of features for that price --- and the main advantage is that it's a framework, i.e. if you don't need a particular feature, you don't have to install it.
Eclipse is for IDEs what EMACS is among editors: their common property is that whatever feature you come up with that (you thing) you need, odds are high in the 90% range it's either already in the core package, or somebody has already written a plugin/module to do it.
It's not really all that bad. The default installation plus CDT plugin works fine as a generic IDE for C programs. It'll blow quite a number of vendor's self-made IDEs clean out of the water already. I've seen enough crappy IDEs in my time to have learned this: the world is better off with compiler writers not putting their time into user interface programming. The skillsets are just too different.
Specialist knowledge only gets involved if you were to make your own Eclipse plugins to, e.g., make an equivalent of uVision's devicse database and simulator engine part of Eclipse. And I rather much doubt that connecting such an engine into Eclipse is really harder than building your own IDE, project management, compiler option management, etc., from scratch.
Release documentation of Eclipse 3.5 seems to contradict you on that.
I appreciate all of the help and constructive criticism that I have received as feedback for my post. It seems that of the few people that I have got feedback from do NOT use column editing features. I don't know how you deal with that when you have to write hundreds of lines of code that are similar to the definition of several variables all the way to the level of functions. I would much rather write one line than one hundred, but I guess that's just me. You are right however, I could just copy the text that I want to manipulate and move it to the program that I know can execute column editing and paste it in. It's really not that tough, but it would be nice to have that available within the uVision IDE. In any event, it's still pretty frustrating to buy a software package and get no documentation that identifies all of the editing posibilities. In this case I had to go on a rabbit chase on the web to find out if something was available within the IDE instead of being able to find it within the IDE's documentation.
If you post an example of what you start with, and what editing you need to do, we might be able to give you suggestions what editing we do for similar problems.
If many things needs to work on a large set of variables, I normally use a struct. Then I can create a single variable of that struct at many places, instead of having to create a large number of variables again, and again.
Often, when I see repetitions, I have a strong reason to repackage the code into reusable modules instead of having multiple sets of similar code.
