Does anyone know how to use column mode for editing source code within uVision3 IDE??? I am used to using Jens where I could insert text in a column format defined by the start and stop of the drag of my cursor. I could then right click and insert defined text on all lines simultaneously starting where my cursor orignated to the end of the highlighted segment area in a column format. Can anyone help with this??? I know how to use the Alt key and mouse to highlight text in a column format, but I can find a way to enter text on multiple lines in a column format. This is very annoying.
I use column editing quite a bit too. My solution is to edit and build within SlickEdit. The build button in SlickEdit can be configured to call uVision with the -b option to build a project. Errors are redirected to the build window so the error parser can see them. The only time I use uVision is to setup or modify a project. Yes, this is a workaround but it works pretty well for me and sure beats using the uVision editor. I prefer using eclipse with the SlickEdit core plug-in. Hopefully someday Keil will see the light and switch to the eclipse framework like many others have.
-Walt
I'm quite happy Keil is _not_ using the eclipse framework.
"It seems that of the few people that I have got feedback from do NOT use column editing features"
Not the specific "column editing feature" that you're speaking of - but I do quite often use the feature as found in uVision.
"I don't know how you deal with that when you have to write hundreds of lines of code that are similar to the definition of several variables"
I would write the first one, copy, paste it as many times as required, then overtype the bits that differ. Or start with a "skeleton", copy-&-paste, then fill in the blanks.
"I could just copy the text that I want to manipulate and move it to the program that I know can execute column editing and paste it in"
That's one way to do it. Alternatively, just open that file in the other editor - no need for copy/paste between applications.
As Per says, if you're routinely getting into that situation, maybe you should be looking at a better way to structure the code...?
"It would be nice for one if a company took into consideration all of the editing features that are used by 99% of the software programming community"
that's precisely what the ide does not offer the column editing mode you are looking for: 99% of the software programming community does not use it.
that doesn't mean that nobody uses it. just that there isn't sufficient number of people using it to justify its existence in the ide.
some comments: I do not know about "99% of the software programming community" but I am a heavy user of column editiing: a) /* some inactive code */ b) //inactive ... //inactive ... //inactive ... b) is dead easy with the colun editing in CodeWright. b) has the HUGE advantage that the disabled lines show up as disabled on global searches.
The editor in the IDE of any small micro Compiler maker I know of STINKS. I am not suggesting they should redirect their efforts from compiler/linker to the editor, they should accept the fact and make an interface so that e.g. CodeWright could be hooked in.
the comment above about "going outside the IDE" is ridiculous, how big an effort is it to click on the taskbar instead of on "edit"
"but it would be nice to have that available within the uVision IDE."
it would be nice. but writing an ide is very much writing a piece of code: there are lots of nice things that we could but don't do in our code.
As a matter of fact, the greatest code we write has left out many nice features. and probably because of that, it is the greatest code we have written.
"Often, when I see repetitions, I have a strong reason to repackage the code into reusable modules instead of having multiple sets of similar code."
agree with that.
"make an interface so that e.g. CodeWright could be hooked in."
alternatively, it is not that difficult to embed the compiler in your own choice of editors (SI, CB, etc.).
As I've already mentioned, it's easy too hook Codewright in to edit the selelcted file from the uVision Project view, or the current file in the uVision editor - including going to the current line.
And there are documents here for hooking in to the debugger: http://www.keil.com/appnotes/list/uvision.htm
Note that a number of programmers editors have special features for comment away code, so you can do your alternative "b" without any column editing involved.
I can hook anything into uVision then? For example, I can hook Jens into uVision in the same manner as proposed for hooking in Code Wright???
Regarding column editing: I've used it in M, Brief, MSVC, Eclipse and Notepad++. When an IDE/editor doesn't support it I sorely miss it. Arguments along the lines of "maybe you're not structuring your code right" are not really acceptable.
Regarding Eclipse: it may not be the best IDE but to me it seems good enough that I wouldn't be too upset if all the embedded vendors standardized on it.
Regarding uVision integration: it would be nice to have a better way of plugging editors and other tools into uVision but I here's what I've been doing as a second-best solution:
- Set up a fake CDT project in Eclipse (trivial) - Set up a custom build command file that calls uVision to build the project in the background and pipe the errors back to Eclipse (easy) - Set up an error parser that makes errors and warnings show up in Eclipse's "problems" tab (moderately easy)
Eclipse's SVN and CVS integration is great, by the way. Makes source control so much easier to use.
Now I can do all my editing and building in Eclipse and when it's time to debug I switch over to uVision for debugging. Since the uVision debugger is pretty good I'm not too upset about not having debugging in Eclipse.
Andrew
Now I can do all my compiling and linking in uVision and when it's time to edit I switch over to CodeWright for editing. I'm not too upset about not having editing in uVision.
have you considered making that "open source"?, you might get a beneficial return
I do not want to use tools written in coffee, my time is too precious
"Regarding Eclipse: it may not be the best IDE but to me it seems good enough that I wouldn't be too upset if all the embedded vendors standardized on it."
is it possible that others think the Keil IDE, without the column editing feature, is good enough for them too?
maybe that's why they didn't include a column editing feature?
If you really miss it that much, maybe you can talk to Keil to write a special IDE for you. I am sure that as long as you put big enough of a figure in front of them, they will move in your direction.
