Hi everyone, I'm learing to program in keil c. anyone help me to generate PWM signal using interrupt. I am using xc164cs controller and i have starter kit also. problem is i have written code using interrupt but while running the prog it is not entering into the interrupt service routine function. I had set global interrupt enable. another problem is the GPT is running but the overflow latch value toggles randomly(not specific to the time period). so anyone help me to make the timer run properly and to use interrupt service routine properly.If there is any sample program attach me..
Thanks in advance
Raj.
Have you not looked at http://www.keil.com/download/list/c166.htm ?
Hello Andy, Thanks for ur reply... I cudnt find any program for xc164cs using interrupt service routine..
hey Rajkumar ;;;;;
u want to change the pwm after 5 seconds? ;;;;;
where is the pm for this forum? ;;;;;;;;;;;
i send you the code? ;;;;;;;;;
it works 1000% perfectly and has no bugs ;;;
Kashmala
Hi kashmala...
Thanks for ur reply
wer s d code ... i din find any code wit ur reply.
nooooooo;;;;;;;
this forem sucks;;;;
no pm;;;;
no attachmentz;;;;;;
file\\e:\very big projects\timerz and stuf\wit isr
njoy
From what I can tell, your message clearly indicates that if there is something on this page that sucks, it's you.
who asked you?;;;;;;;;
woshgatishmeteshing!;;;;
lol;;;;;;;;;;
Now that is officially established that you are a moron, you can explain what "woshgatishmeteshing" means. I'm overwhelmed.
Ho, yeah.
>^C >break sent to fool feedback loop >
biiiiig man?;;;;;;
u r ne andartaal or wot?;;;;;;;;;;;;;;;;;;
