receive data in buffer uart1
hi..
I am using LPC2387 board.
By using sample code of UART1 i am trying to store data in buffer.
I am sending Data using .exe
Data sent by .exe is in byte.
but I cant store this data in buffer.
Can any one help me to figure out from this problem. below is the code.
void UART1Handler (void) __irq
  BYTE IIRValue, LSRValue;
  BYTE Dummy = Dummy;
  IENABLE;                              /* handles nested interrupt */
  IIRValue = U1IIR;
  IIRValue >>= 1;                 /* skip pending bit in IIR */
  IIRValue &= 0x07;                 /* check bit 1~3, interrupt identification */
  if ( IIRValue == IIR_RLS )            /* Receive Line Status */
        LSRValue = U1LSR;
        if ( LSRValue & (LSR_OE|LSR_PE|LSR_FE|LSR_RXFE|LSR_BI) )
          /* There are errors or break interrupt */
          /* Read LSR will clear the interrupt */
          UART1Status = LSRValue;
//        Dummy = U1RBR;                /* Dummy read on RX to clear
//                                                      interrupt, then bail out */
          IDISABLE;
          VICVectAddr = 0;              /* Acknowledge Interrupt */
          return;
        if ( LSRValue & LSR_RDR )   /* Receive Data Ready */
          /* If no error on RLS, normal ready, save into the data buffer. */
          /* Note: read RBR will clear the interrupt */
          UART1Buffer[UART1Count] = U1RBR;
          UART1Count++;
          if ( UART1Count == BUFSIZE )
                UART1Count = 0;         /* buffer overflow */
  else if ( IIRValue == IIR_RDA )       /* Receive Data Available */
        UART1Count++;
//      if (UART1Count > 90)
//        UART1Count++;
  else if ( IIRValue == IIR_CTI )       /* Character timeout indicator */
        /* Character Time-out indicator */
        UART1Status |= 0x100;           /* Bit 9 as the CTI error */
  else if ( IIRValue == IIR_THRE )      /* THRE, transmit holding register empty */
        /* THRE interrupt */
        LSRValue = U1LSR;               /* Check status in the LSR to see if
        valid data in U0THR or not */
        if ( LSRValue & LSR_THRE )
          UART1TxEmpty = 1;
        else
          UART1TxEmpty = 0;
  IDISABLE;
if ( PortNum == 1 )
#if EA_BOARD_LPC24XX
        PINSEL7 |= 0x0000000F;  /* P3.16 TXD1, P3.17 RXD1 */
#else                                           /* Default is Keil MCB2300 board */
        PINSEL0 |= 0x40000000;  /* Enable TxD1 P0.15 */
        PINSEL1 |= 0x00000001;  /* Enable RxD1 P0.16 */
#endif
    U1LCR = 0x83;               /* 8 bits, no Parity, 1 Stop bit */
    Fdiv = ( Fpclk / 16 ) / baudrate ;  /*baud rate */
    U1DLM = Fdiv / 256;
    U1DLL = Fdiv % 256;
        U1LCR = 0x03;           /* DLAB = 0 */
    U1FCR = 0x07;               /* Enable and reset TX and RX FIFO. */
    if ( install_irq( UART1_INT, (void *)UART1Handler, HIGHEST_PRIORITY ) == FALSE )
          return (FALSE);
    U1IER = IER_RBR | IER_THRE | IER_RLS;       /* Enable UART0 interrupt */
    return (TRUE);
  return( FALSE );
void UARTSend( DWORD portNum, BYTE *BufferPtr, DWORD Length )
  if ( portNum == 0 )
    while ( Length != 0 )
          /* THRE status, contain valid data */
          while ( !(UART0TxEmpty & 0x01) );
          U0THR = *BufferPtr;
          UART0TxEmpty = 0;     /* not empty in the THR until it shifts out */
          BufferPtr++;
          Length--;
  else
          while ( !(UART1TxEmpty & 0x01) );
          U1THR = *BufferPtr;
          UART1TxEmpty = 0;     /* not empty in the THR until it shifts out */
         // BufferPtr++;
          Length--;
  return;
int main (void)
//  UARTInit(0, 115200);        /* baud rate setting */
  UARTInit(1, 115200);  /* baud rate setting */
  while (1)
  {                             /* Loop forever */
//      if ( UART0Count != 0 )
//        U0IER = IER_THRE | IER_RLS;                   /* Disable RBR */
//        UARTSend( 0, (BYTE *)UART0Buffer, UART0Count );
//        UART0Count = 0;
//        U0IER = IER_THRE | IER_RLS | IER_RBR; /* Re-enable RBR */
        if ( UART1Count != 0 )
          U1IER = IER_THRE | IER_RLS;                   /* Disable RBR */
          UARTSend( 1, (BYTE *)UART1Buffer, UART1Count );
          UART1Count = 0;
          U1IER = IER_THRE | IER_RLS | IER_RBR; /* Re-enable RBR */
  return 0;
Please help me to get out from this problem.
I have spent two days behind this problem but still don't get its solution.
It will be very helpful to me.
