Hi!
I start to learn STM32 (STM32F103GB on MCBSTM32 board, example project "blinky") and have faced with following problem: I can't insert breakpoint in C and "insert/remove breakpoint" button on Debug Toolbar always disabled. The only way to define breakpoint is double-click on grey window bar in disasm window. Program executed, breakpoint in disasm occurs... but what can I do to use breakpoits in C?
Regards, Ilya.
Did you build with debug information, so the editor can translate from source code line to assembler instruction?
what is wrong code does not compile properly.
\\file\\drivec\keil\c51\example\ringer\tang.c
Get your own thread, and this time don't expect people to hack your computer to look at your source code.
To post all required information - including error messages.
Maybe I do something wrong? (workflow on printscreens at link: www.flickr.com/.../53850447@N05/?saved
I can't see your Output tab - do you have turned on debug information there?
By the way - you post small images where most of the image is wasted with the editor. Either post your photos at full screen resolution, or reduce the size of the IDE so that the relevant information fills more of the image.
It's so strange... I try to use ST-LINK as in-circuit debugger and it's correctly work with JTAG interface. But gives errors with SWD when I try to enter a debug session. These errors displays in windows with "OK" button only. First: "internal command error", second: "error while attempting to write 16 bytes to 0x1ffff800". And at result situation like with J-Link - program code executed, breakpoints avaliable only in disasm window. Printscreen with errors and debugger options at link: www.flickr.com/.../53850447@N05/?saved=1
The text from command window:
Set JLink Project File to "C:\my_temp\Blinky\JLinkSettings.ini" JLink info: ------------ DLL: V4.15n, compiled Jun 18 2010 19:55:09 Firmware: J-Link ARM-Pro V1.x compiled Jan 22 2010 19:00:58 Hardware: V1.10 S/N : 171100029 Feature(s) : RDI, FlashBP, FlashDL, JFlash, GDB * JLink Info: TotalIRLen = 9, IRPrint = 0x0011 * JLink Info: Found Cortex-M3 r1p1, Little endian. * JLink Info: TPIU fitted. * JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots ROMTableAddr = 0xE00FF003 Target info: ------------ Device: STM32F103VB VTarget = 3.325V State of Pins: TCK: 1, TDI: 0, TDO: 0, TMS: 0, TRES: 1, TRST: 1 * JLink Info: TotalIRLen = 9, IRPrint = 0x0011 * JLink Info: Found Cortex-M3 r1p1, Little endian. * JLink Info: TPIU fitted. * JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots Hardware-Breakpoints: 6 Software-Breakpoints: 2048 Watchpoints: 4 JTAG speed: 3000 kHz Load "C:\\my_temp\\Blinky\\Obj\\BlinkyOPT.AXF" Verify failed on VerifyBlock()*** error 57: illegal address (0x1FFFF800) * JLink Info: TotalIRLen = 9, IRPrint = 0x0011 * JLink Info: Found Cortex-M3 r1p1, Little endian. * JLink Info: TPIU fitted. * JLink Info: FPUnit: 6 code (BP) slots and 2 literal slots
In your project options (Alt+F7) - Output tab: Debug Information should be checked - Linker tab: Misc. controls should contain --debug With these options set, rebuild your project and see if you can place breakpoints in your C code
I added printscreens with these options (see at link for previous pictures). The result remained the same...
Are you able to set breakpoints if you debug using Simulator? (In the Debug tab of your project options it is from left)
Thank you for your attention! The problem solved.
Shouldn't you tell how you solved your problem?
Reinstall Keil and jLink drivers... That's all.
I am useng newest version of MDK-ARM and ST-Link programmer. When program is downloaded and run, it is not possible to set or clear breakpoints. You must stop the program, set breakpoints and start program. This is not issue with hardware, because this works with IAR IDE.
Any ideas how to get this functionality in Keil IDE?
I have J-link and ULINK debuggers. Using ULINK I can set and clear breakpoints even when the software runs, but if I use J-link I can only set/clear first breakpoint, and I cannot set second breakpoint until I stop execution. I don't know what is causing this but I don't think it's a big deal to stop and then set a breakpoint.
