How do I access a variable in bank 0 ?
If I look in my .m51 file I see my var ISP_VERSION:
CODE 754EH 001AH UNIT ?CO?ISP_VERSION
Now I try to access this var from a different image in a different bank using C code:
ispversion = 0x754E;
sprintf(SendString,"\r\nISP version %s",ispversion );
THIS DOES NOT WORK IT SEEMS!!!
This code is part of my main() function. I see in the .m51 file of this image:
CODE 011DH 0BCAH UNIT ?PR?MAIN?MAIN
But I do not really understand in which bank the main functionis located. I see in my .m51 file also (if relevant):
TYPE BASE LENGTH RELOCATION SEGMENT NAME ----------------------------------------------------- * * * * * * * D A T A M E M O R Y * * * * * * * REG 0000H 0008H ABSOLUTE "REG BANK 0" REG 0008H 0008H ABSOLUTE "REG BANK 1" REG 0010H 0008H ABSOLUTE "REG BANK 2"
I also tried this C code but it did not work as well:
unsigned char code *ispversion;
ispversion = (unsigned char code*)0x754E;
you see: I am not a banking expert (yet)!
"you see: I am not a banking expert (yet)!" You are also not a C expert ;)
Note that 0x754E is a number.
But when you print with %s you are trying to print a text string not a number.
The normal C string to print a 4-digit wide hexadecimal number is %04x (or %04X if you want capital letters).
well...
0x754E is the location (address) of the data where my data is located. The variable ispversion is a character pointer which (I hope) is pointing to this location. So I do not think the C here is the issue...
