Hello everyone. I'm beginner for ASM programming. I tried programming by using modular programming method in ASM. I built 2 modules (seperately): delay_s.a and main.a. delay_s.a:
;=========================================================================== ;Description: ; ; - in: delay_s_i ; - out: non ;=========================================================================== ;=========================================================================== PUBLIC delay_s_i, delay_s ;=========================================================================== ;=========================================================================== ?DT?delay SEGMENT DATA RSEG ?DT?delay delay_s_i: DS 1 ;reserve 1 byte ;=========================================================================== ;=========================================================================== ?PR?delay SEGMENT CODE RSEG ?PR?delay delay_s: MOV A, delay_s_i MOV B, #14 ;to delay approximately 1s - don't care about it MUL AB ; MOV delay_s_i, A MOV A, #0 SETB TR0 loop1: JNB TF0, $ CLR TF0 DEC delay_s_i CJNE A, delay_s_i, loop1 RET ;============================================================================ ;============================================================================ END ;============================================================================
main.a:
extrn code (delay_s) extrn data (delay_s_i) org 0000h mov sp, #7fh main: clr p2.0 mov delay_s_i, #1 call delay_s setb p2.0 mov delay_s_i, #1 call delay_s jmp main end
Compiling is ok. I used the debug tool to test and i realized that the delay function is not returned to main function. I don't know why. I need some help please. Thank you
loop1: JNB TF0, $
What happens with this one-line loop depending on TF0 contents? Might it affect your 1-second delay time?
Thanks for your reply. I checked my program again, and I realized that i forgot to config Timer 0 in 16 bit mode. (MOV TMOD, #00000001b) in main function. And I run debug again, but the program still doesn't work. I expose here two modules (delay.a and main.a) again. main.a
extrn code (delay_s) extrn data (delay_s_i) org 0000h jmp start org 0050h start: mov sp, #7fh mov TMOD, #00000001b ; Timer 0 - 16bit mode main: clr p2.0 mov delay_s_i, #1 call delay_s setb p2.0 mov delay_s_i, #1 call delay_s jmp main end
delay_s.a
;=========================================================================== ;Description: ; - delay for approximately 1 s ; - in: delay_s_i ; - out: non PUBLIC delay_s_i, delay_s ;===================================================== ?DT?delay SEGMENT DATA RSEG ?DT?delay delay_s_i: DS 1 ;===================================================== ?PR?delay SEGMENT CODE RSEG ?PR?delay delay_s: MOV A, delay_s_i MOV B, #14 MUL AB MOV delay_s_i, A MOV A, #0 SETB TR0 loop1: JNB TF0, $ CLR TF0 DEC delay_s_i CJNE A, delay_s_i, loop1 RET END
Running debug again, when encounter the
call delay_s
in main function, there's an error in debug window, it's "error 65: access violation at I:0x81: no 'write' permission.; it means the address of next instruction was not pushed into stack and I think this causes the problem. When encounter
RET
, there's no value popped out of stack (and 0 value popped out instead), and the program restart at 0000h, not be returned to where it was called.
Thanks and wait for your answers.
there's an error in debug window is it the Keil simulator is it the SILabs emulator is it the ultramon monitor is it the acme whatschamacallit is it ....
nobody can help you if tou keep secrets
in main function, there's an error in debug window does it even compile without a prototype? or are you one of those that ignore warnings?
Ahem, Erik, are you aware that we're talking about a piece of assembly code here, as in: code to which the concept of a prototype declaration doesn't even apply? Nor that of "compiling", for that matter?
Ahem, Erik Sunday morning sleepies. OOPS
still need to know what "the debugger" is
Sorry for not supplying enough information. I'm just beginner using Keil C, and i don't know much. I don't mean to keep secret. I'm using Keil Simulator.
Erik; You need to cut some slack for OPS that use the Keil terms for their simulator. Keil calls it a "Debugger" in all their sales documents and in their operation manuals. Yes, it is a simulator but connected to a target board it can rightly be called a "Debugger". So, let the OPS call it a debugger. It's not difficult to discern what they mean. Bradford
It's not difficult to discern what they mean. ... where 'discerning' has led a thread astray
Hello. I solved my problem. When initializing the stack, i used "MOV SP, #7F", so, I can't use "push" instruction because the address above 7F is SFRS, not for stack. Thanks
today, only a few derivatives will not 'run' the stack to 0xff you did not mention which derivative you were using.
Most beginners makes omissions in their first visit to the forum, no 'blame', just remember.
