IRQ Not Firing
I am writing an I2C master transmitter object. The problem I am having is that the IRQ Handler for I2C1 is not firing. According to the manual, it should fire after the start condition is sent and the status register is 0x08. When I step through the code with the debugger, the status code is 0x08. I am using an MCB1700 development board. Why is it not firing? Did I not configure something properly? For tests, All I am doing is toggling an LED on when the interrupt fires. Once I solve this problem, I will write the rest of the code.
#include <stdio.h>
#include <LPC17XX.h>
#include "GPIO1Output.h"
GPIO1Output out(P1_28);
__irq void I2C1_IRQHandler(void)
        if (LPC_I2C1->I2STAT == 0x08)
             out.Set();
int main(void)
        // Initialize I2C.
        LPC_PINCON->PINSEL0 = 0x0F;
        LPC_PINCON->PINMODE_OD0 = 0x03;
        NVIC_EnableIRQ(I2C1_IRQn);
        LPC_I2C1->I2CONSET = 0x40;
        LPC_I2C1->I2CONSET = 0x20;
        int status = LPC_I2C1->I2STAT;
  • Mr Andrew Neil. I am just curious what is your day job? I find it hard to believe that you have time to actually do any work, given the number of posts you have made to various forums (Keil and ST to name just two). You seem to have an answer/opinion about everything. I can only hope that you're self employed so you're not doing all this on your employer's time :)
