Suggesstions about TMS750LS20216
I have used LPC arm micros in my student project.
Now for my next project ( Model Rail )i want to use TMS750LS20216 TI micro.
I need suggestions from you peoples.
First one is support from vendor. I mean how much the vendor assist for their product i.e example code, tutorials, technical support team etc.
Second one, is hardware support of the selected device. Is there enough support for these devices form third party vendors? like debuggers/compilers etc.
You may say i should use google???
Yes used it and searched many things but in addition i need your experience about this device and its support.
Thanks in Advance!
Have a nice day!
  • Sorry, but I'm not sure if the NDA is still in effect. The chip is now officially documented on the manufacturers web site, but it get's extra touchy since we are talking about chip problems not - at least yet - mentioned in any official documents.
    My previous post, on the other hand, was just standard SPI use between a "normal" SPI master/SPI slave, where the slave uses an attention line to turn on/off the communication when needing to send data while the master is idle.
  • I wasn't talking about switching who is master or slave. But the slave having the potential to tell the master to start sending null data if the master haven't anything meaningful to send. This allows the chips to enter sleep while any side may reactivate the SPI communication. The previous processor we used on the master side had the slave select input sharing pins with the second ethernet controller, making it impossible for it to be an SPI slave. But the system still needed either side to be able to activate full duplex communication. So A may stream data or commands to B and receive acknowledges back while B may stream data or commands to A while receiving acknowledges. So the master may say "activate output x" and get an acknowledge on that while at the same time the slave may say "here is the measurements from the analog inputs" and get an acknowledge on that. Or maybe a huge stream of incomming or outgoing CAN data.
