Hi, When I create task and debug function fi_Test1 program crach on acces to memory. What is cause of it? Thank You
int fi_Test1(void) { int res; START_LOCK (int); RETURN (res); END_LOCK; } __task void fv_SdCard_10ms (void) { // fv_InitCard(); fi_Test1(); for (;;) { os_dly_wait (1); } } //----------------------------------------------------------------------------- __task void init (void) { fv_SendMenuStr("\rSystem start \r\n"); fv_SendMenuStr("Wejscie do MENU poprzez 'M' \r\n"); t_phaseA = os_tsk_create(fv_TerminalTask, 1); t_phaseB = os_tsk_create(fv_Task_10ms, 1); t_SdCard = os_tsk_create(fv_SdCard_10ms, 1); os_tsk_delete_self (); } /* Mutex lock macros. */ #define START_LOCK(type) type rval; \ _mutex_acquire(&_stream_list_lock); #define RETURN(x) rval = (x); \ goto end_of_func; #define END_LOCK end_of_func: \ _mutex_release(&_stream_list_lock); \ return (rval);
Err, I'm missing a call to "os_mut_init"?
And get rid of these goto statements!
"And get rid of these goto statements!"
Looks like a direct (partial) copy from the Keil source code (File_Config.H)
