I googled this 7-seg plugin for uVision (drava.etfos.hr/.../7-seg-LEDs_en.htm) & it felt perfect for simulating my asm code without leaving uVision.
But for the love of my life I cannot get the 7-Seg Simulator to work. I doesn't seem to be following the conventional rules.
SETB P0.0 MOV P1, #3FH
does not give 0 on the LED set as
<..SFRPortAddress="0x90" ..> <commonTerminal SFRPortAddress="0x80" bitPosition="0" activeOn="1" />
and set to activeOn = "1"
The C example given seems to work fine. (If however I remove delay I can't see the changes even while step-debugging)
Any help is greatly appreciated. Thanks.
At the end of that page, it clearly says:
If you have any questions, improvements suggestions, bugs to report ( :-( ), or only to say thanks do not hesitate to contact me via e-mail.
bboris<insert-at>etfos<insert-dot>hr
Did you do that?
I was hoping the issue might be on my part & not a "bug" in the plugin. Hence taking it as a last resort.
On an unrelated topic: are R0 & @R0 mutually exclusive?
"The C example given seems to work fine. (If however I remove delay I can't see the changes even while step-debugging)"
does that seem like a code that's working fine?
