RTX51 Tiny system function (os_wait)
Hi. I've performed a 1 Hz incremental counter with RTX51 Tiny functions. I configured the parameter INT_CLOCK EQU 10000 at the Conf_tny.a51 file configuration, with a 12Mhz XTAL and then I did a task that uses the os_wait function
unsigned int a;
Void Counter(void) _task_ 1 {
while (1)
{ a++;
os_wait (K_TMO, 100, 0);
Theorically, this task is executed every 1 second. The task is waiting 100 timer ticks before a new execution. But it's not working as I expect. What could be wrong?
