MCBSTR7 User's Guide suggests below code to assign interrupt vector addresses. I wonder the second line. It makes first cast to u16 and then shift by 16 bits. I checked the code in debug, the compiler generates 32 bits shift even it requests u16 bit. Should it be casted to u32 instead of u16?
// Configure and enable IRQ for Timer 3 EIC->IVR = (u32)T3TIMI_IRQHandler; // setup IRQ vector EIC->SIR[T3TIMI_IRQChannel] = ((u16)T3TIMI_IRQHandler << 16);
MCBSTR7 User's Guide: www.keil.com/.../mcbstr7_ex_keil_locate.htm
10x.
The cast to u16 chops off the upper 16 bits. The shift is done on an int thanks to integer promotion rules. Using a cast to u32 instead would also work since the upper 16 bits would be thrown away during the shift anyway. It would also be slightly more intuitive, I think.
Which is superfluous, since those upper 16 bits will be shifted into oblivion anyway. So that cast achieves nothing worth having.
And that is a potentially serious bug. 'int' is signed, and you pretty much never want to shift signed values. Evaluating
(int)0x8000 << 16
causes undefined behaviour on a 32-bit platform like this.
