Option needed to have a flashed program working
Hi all, I need help,
I have a strange behavior with my program when I try to flash my LPC3240 uC.
When I have the emulator running the program, this one works as I expect that it has to work. Then, I am building the bin file with the command:
fromelf.exe --bin --output ..\Obj\myProg.bin ..\Obj\myProg.axf
I flash the myProg.bin into an external flash.
Depending on the option I choose on the Keil environment in Code Generation area, specialy the option Floating Point Hardware, the file .bin I am flashing doesn't work at all or doesn't work as the emulated program works.
Do I miss something ?? I don't understand
Regards,
Colagrossi Jean-Marc
