Dear all,
I am using Keil evaluation version 4 for ARM, on target device LPC2119.I am programming using assembly language.Below are the details of my keil evaluation version.
IDE-Version: µVision V4.00u Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2009
Tool Version Numbers: Toolchain: RealView MDK-ARM Version: 4.03a Toolchain Path: BIN40\ C Compiler: Armcc.Exe V4.0.0.524 [Evaluation] Assembler: Armasm.Exe V4.0.0.524 [Evaluation] Linker/Locator: ArmLink.Exe V4.0.0.524 [Evaluation] Librarian: ArmAr.Exe V4.0.0.524 [Evaluation] Hex Converter: FromElf.Exe V4.0.0.524 [Evaluation] CPU DLL: SARM.DLL V4.03a Dialog DLL: DARMP.DLL V1.46 Target DLL: BIN\UL2ARM.DLL V1.55 Dialog DLL: TARMP.DLL V1.46
I am trying to use the EQU directive but for unknown reason it always gives me the following error for the program below.tHIS ERROR IS ALWAYS INTRODUCED WHEN i USE THE equ DIRECTIVE.Can you please help me about this issue on how to solve it.Thanks in advance for your great support and feedback.
gpio.src(3): error: A1163E: Unknown opcode pinsel , expecting opcode or Macro
///PROGRAM//////////////////////////////////
pinsel EQU 0xE0028000
AREA gpio, CODE, READONLY
ENTRY
start LDR R0,=0xE0028000 MOV r0, #2 MOV r1, #3 ADD r0, r0, r1 stop MOV r0, #0x18 LDR r1, =0x20026 SVC #0x123456 END
