MCB2300 TCPnet application with RTX not working
Hi !
I'am compiling a TCP application based on the http demo.
My problem is that the application is not responding to ARP request, as it if was dead.
Indeed, I've put a led toggle in timer_task and tcp_task and they are alive.
I've tested many thing :
Put init_TCPnet() before os_init()
Use Round-Robin
put tcp_get_socket in the main()
Here is the code of my main.c :
#include <RTL.h>
#include <stdio.h>
#include <LPC23xx.H>
#include "ui/ui.h"
#include "led/led.h"
// Define here the priority for your task
//! Init Task must have the higher priority
#define PRIO_INIT 100
#define PRIO_TIMER_TSK 30
#define PRIO_UI_TSK     1
#define PRIO_CONTROL_LOOP 99
//! stack for the ui task
   howto declare : see os_tsk_create_user.
U64 g_ui_stack[800/8];
__task void init (void) ;
int main (void) {
   /* Start with 'init' task. */
   os_sys_init(init);
   while(1);
   /* Add System initialisation code here */
   init_TcpNet ();
   LED_Init() ;
   LED_Out(0) ;
   /* Initialize Tasks */
   os_tsk_prio_self (PRIO_INIT); // Set ourself to higher priority
   os_tsk_create (ui_timer_task, PRIO_TIMER_TSK);
   os_tsk_create_user (ui_task, PRIO_UI_TSK, &g_ui_stack, sizeof(g_ui_stack));
   os_tsk_delete_self(); // delete myself and start other task execution.
Here is the code for my ui :
#include <RTL.h>
#include <Net_Config.h>
#include <string.h>
#include "ui.h"
//! Order received by GUI & target returns
typedef enum
        STOP = 0, //!< Stop experience
        LAST
} T_ORDER;
//! Define parameters for a task
typedef struct
        U32 uiEnable    ;
} T_TASK_PARAM ;
// Order + size fields
#define FRAME_HEADER_SIZE 8
//! Structure of the Received orders.
typedef struct
        T_ORDER order;
} T_CLIENT_FRAME ;
//! Sent Frame
typedef struct
   U32 uiOSClock ;
} T_SERVER_FRAME ;
#define NB_CONTROL_LOOP 10000
//! GUI socket
static U8 g_socket_tcp;
static T_CLIENT_FRAME g_ClientFrame ;
static T_SERVER_FRAME g_ServerFrame ;
static U8 g_BytesRead ;
U16 ui_callback (U8 soc, U8 evt, U8 *ptr, U16 par) ;
static void tcp_launch_tasks(void) ;
static void tcp_stop_tasks(void) ;
static void tcp_send_data(void) ;
#ifndef htonl
    #define htonl(a)                    \
        ((((a) >> 24) & 0x000000ff) |   \
         (((a) >>  8) & 0x0000ff00) |   \
         (((a) <<  8) & 0x00ff0000) |   \
         (((a) << 24) & 0xff000000))
#endif
#ifndef ntohl
    #define ntohl(a)    htonl((a))
#endif
#ifndef htons
    #define htons(a)                \
        ((((a) >> 8) & 0x00ff) |    \
         (((a) << 8) & 0xff00))
#endif
#ifndef ntohs
    #define ntohs(a)    htons((a))
#endif
__task void ui_task (void)
        unsigned int i = 0 ;
        g_BytesRead = 0 ;
        memset(&g_ClientFrame, 0, sizeof(g_ClientFrame)) ;
        memset(&g_ServerFrame, 0, sizeof(g_ServerFrame)) ;
        /* Initialize TCP server Socket and start listening */
        g_socket_tcp = tcp_get_socket (TCP_TYPE_SERVER, 0, UI_SOCKET_TIMEOUT, ui_callback);
        if (g_socket_tcp != 0)
                tcp_listen (g_socket_tcp, PORT_NUM);
                while (1)
                        main_TcpNet() ;
                        os_tsk_pass() ; // schedule
                        ++i ;
                        if (i > 100000)
                                LED_Toggle (1) ;
                                i = 0 ;
__task void ui_timer_task (void)
   /* System tick timer task */
   os_itv_set (10);
   while (1)
      timer_tick () ;
      os_itv_wait (); // Wait and schedule
          LED_Toggle (0) ;
static void ui_process_frame (void)
        // Toogle led
        LED_Toggle (1) ;
        // convert indianness
        g_ClientFrame.order = (T_ORDER) ntohl(g_ClientFrame.order) ;
        g_ClientFrame.size      = ntohl(g_ClientFrame.size) ;
        switch(g_ClientFrame.order)
                case START :   // only convert data to be interpreted
                        tcp_launch_tasks() ;
                        break ;
                case STOP :
                        tcp_stop_tasks() ;
                        break ;
                case DATA :
                        tcp_send_data() ;
   /* This function is called by the TCP module on TCP event */
   /* Check the 'Net_Config.h' for possible events.          */
   if (soc != g_socket_tcp) {
      return (0);
        switch (evt)
                case TCP_EVT_DATA:
                        /* TCP data frame has arrived :
                                We frame receive portion of the frame so we shall control data received
                        break;
                case TCP_EVT_CONREQ:
                        /* Remote peer requested connect, accept it if socket available */
                        switch( tcp_get_state(g_socket_tcp) )
                                case TCP_STATE_CLOSED:
                                case TCP_STATE_LISTEN:
                                        return (1);
                                default :
                                        return 0 ;
                case TCP_EVT_CONNECT:
                        /* The TCP socket is connected */
                        return (1);
                case TCP_EVT_CLOSE :
                case TCP_EVT_ABORT :
                        /* Keep the socket allocated for further connection */
                        break ;
                default:
                        break ;
   return (0);
        U8 * sendbuf ;
        U32 size = FRAME_HEADER_SIZE + g_ClientFrame.size ;
        g_ClientFrame.order     = (T_ORDER) htonl(g_ClientFrame.order) ;
        g_ClientFrame.size      = htonl(g_ClientFrame.size) ;
        // check socket availability
        if (tcp_check_send(g_socket_tcp) == __TRUE)
                sendbuf = tcp_get_buf(size) ;
                memcpy(sendbuf,&g_ClientFrame,size) ;
                if ( tcp_send(g_socket_tcp, sendbuf, size) == __FALSE)
                        // hdle frame send error.
        // else abord sending... CAN add some code to place the frame in a buffer.
I'm getting crazy comparing with http demo without find THE Difference !!
Thanks for any help !
