Simple Parallel to Serial based Interface
Hi Everyone,
The first project I would like to share with you is one made out of a need to grab the printed output from a piece of medical equipment that only had a parallel port.
It is currently fixed at 38,400 baud on the serial port but this is tricky to change.
As the code is only 87% of the memory space on the chip, you can make whatever changes you want.
I will attach the Eagle Schematic and board, as well as the source code in C (compiler).
(Zipped - password is Zipped)
Any questions, please ask.
-Moal
