Copy C-Lib to RAM using the linker
Hi all,
I've got a question regarding a bootloader written for the XE167.
Part of the bootloader needs to be executed in RAM in order to erase and reprogram the FLASH. I placed the flash-routines in their own section and advised the linker to execute them from the RAM.
When looking at the ASM-output of the routines I noticed that there are some calls to the C_SCALLI-function of the C-Lib within these routines.
Because of these calls I need to copy the C-Lib code to the RAM, too.
The thing is that I need to copy the code from FLASH to RAM before erasing the FLASH. With the flash-routines it was quite easy using the SROM_PS-macros (according to appnotes 141 and 138). This works fine.
Copying the C-Lib using hard coded addresses works fine as well, but for obvious reasons I'd like to use macros to determine the start and end address of the C-Lib as well.
So here's what I tried (according to http://www.keil.com/support/docs/2374.htm):
#define SROM_MC(n)                                                  \
extern unsigned char huge _##n##_s_;  /* section source start */ \
extern unsigned char huge _##n##_l_;  /* section len          */ \
extern unsigned char huge _##n##_t_;  /* target address       */
#define SROM_MC_TRG(n) ((void *)       &_##n##_t_)
#define SROM_MC_SRC(n) ((void *)       &_##n##_s_)
#define SROM_MC_LEN(n) ((unsigned int) &_##n##_l_)
SROM_MC (C_LIB_CODE)
hmemcpy (SROM_MC_TRG(C_LIB_CODE), SROM_MC_SRC(C_LIB_CODE), SROM_MC_LEN(C_LIB_CODE));
Now I can use these macros within my code without getting compiler errors, but the linker cannot find the symbols "_C_LIB_CODE_l_", "_C_LIB_CODE_s_" and "_C_LIB_CODE_t_" (unresolved externals). So this tells me that the symbols for the SROM-section of the C-Lib are not created.
How can I create these symbols?
Thanks in advance for any help.
With best regards
P.S.: If it's of any help, here's part of the generated M66-file:
C04000H   C04827H   000828H   CODE  REL   WORD   ---  ---  PUBL  SROM    ?PR?SR1_FLASH
*** '?C_LIB_CODE'  execution at: E09000H
C05000H   C0502BH   00002CH   CODE  REL   WORD   ---  ---  PUBL  SROM    ?C_LIB_CODE
*** '?PR?SR1_FLASH' stored at: C04000H   execution at:
E08000H   E08827H   000828H   CODE  REL   WORD   ---  ---  PUBL  XCODE   ?PR?SR1_FLASH
*** '?C_LIB_CODE' stored at: C05000H   execution at:
E09000H   E0902BH   00002CH   CODE  REL   WORD   ---  ---  PUBL  FCODE   ?C_LIB_CODE
  • Because of these calls I need to copy the C-Lib code to the RAM, too.
    Not really. IMHO a more natural conclusion from this would be that you need to either
    1) change the way you wrote those flash function such that they can be compiled without resorting to support library calls, or
    2) stop trying to do this in C and just write these things in assembler instead.
