Serial communication
Hi, I tried communication between two uC. Steps are
1) uC1 sends a request (1 byte) to uC2.
2) On receiving this byte, uC2 sends three bytes of data to uC1.
3) uC1 waits for completion of the data reception and stores the data in an array.
All the three steps works ( I am able to display the received bytes correctly using LEDs)
But the problem is I need to add about 1sec delay before every time request is sent from uC1.
(I set a flag to low before sending the request, this flag (global bit) is set to one by the UART ISR when 3 bytes are received. After sending the request, the main program waits for this bit to become high, and then proceeds.Without the additional delay, this bit does not seem to change.)
Is there anything wrong in my method? Why this delay becomes necessary?
  • I don't know why you would need a 1-second delay.
    But you do need a delay since it takes more time to send 3 characters than it takes to send 1 character. So the processor sending 1 character have to spend some time waiting until 3 characters have been received before starting a new request - or the other processor would not be able to pick up all characters and tripple the number of characters to return.
    Another thing - your code should contain a repair timer, i.e. if you haven't received all three characters within a reasonable time, then something must have failed so it isn't meaningful to wait anymore. So throw away any partial result you may have received (zero, one or two characters) and send out your one-byte command again hoping for better luck this time.
    A third thing - when having variables processed by both interrupt handlers and main loop: Do you remember to set them as volatile to force the compiler to always generate a physical read? Without the volatile keyword, the compiler may decide that it already knows the value of the variable.
  • But you do need a delay since it takes more time to send 3 characters than it takes to send 1 character. So the processor sending 1 character have to spend some time waiting until 3 characters have been received before starting a new request -
    In my program I am counting the received bytes and setting the 'data_received ' bit to 1 only after the count reaches 3. The code is given below.
     void Scc1InterruptHandler() interrupt SIO_VECTOR using 2
                       ES = 0; // disable port1 interrupt.
                       if(TI)
                              TI = 0;
                              xmitempty = 1;
                              ES = 1; // enable port1 interrupt.
                              return;
                       RI = 0; // clear RX flag.
                       if(k<3)ph[k]=SBUF;
                       k++;
                       if(k>=3)
                           k=0;
                               data_received=1;
    YES
  • In the main program I am waiting for the bit 'data_received' to become high
    data_received=0;
    sendchar('V');
    while(!data_received);
    But this works only if I add a delay of 1 sec. My doubt is why it doesn't work without that extra delay.
  • Where do you set the delay? After the send but before the while loop?
    It so very much sounds like the while loop is initially sampling the variable "data_received" before it is toggled, and then not performing any other read - i.e. that "data_received" isn't volatile for force a read each turn of the loop.
    By the way - as I mentioned before, your while loop have no timeout. If you somehow get a problem resulting in only two characters being received, you would never get out of the loop. Any distributed code that is expecting an answer from another node must _always_ contain timeout handling to support link breakage, transfer errors, or that the other side may reboot/hang.
    In your case, you don't even know if the other side is powered up when you send your command the first time - so maybe it is that your delay is needed _before_ you send your command, just because you power up both processors simultaneously and tha master is ready to send the first character before the slave is ready to start accepting answers?
    I only quoted part of the program. This is in another while loop and I added delay before send.
    With a time out, it will naturally come out of that loop. But I wanted to see why it doesn't work by checking the data_received bit. Once I ensure this working, I will definitely be adding a time out.
    I wait till uC2 start sending data using the following code in the beginning.
    while(!data_received)// to give time to sensot to boot
                               sendchar('V');
                               wait(1000);
    This part works.
    Also if I avoid
    in the main program and replace it with a fixed delay of 10ms, then also it worke (data is received and displayed correctly). }
    This could misinterpreted.
    you need to wait till the 3 characters are received, but that would be wrong to do by a delay, rarther count the bytes and do not send till 3 are received. It would be prudent to run a timeout on this so that some error handling would take place if the bytes were not recieved before time x.
  • Now the counting of received bytes works. I also provided a time out of 1 second. It is noticed that sometimes it has to time out. Does it mean that counting of bytes do not work always? If so, what could be the reason?
  • You could have a transfer problem.
    Or you could have a problem with your delay.
    How do you implement your delay? If the delay is handled by a timer with one-second granularity, then that delay can result in a zero delay if you call the delay function just before the timer ticks. So have you made sure that your design guarantees a minimum delay time of 1000ms?
  • It could mean that either the counting doesn't work, or bytes are being lost - or, possibly, both!
    "If so, what could be the reason?"
    It's your system and your code - so you need to debug it to find the reason!
    Nobody else has your code or your system - so nobody else can do this for you!
    Here are some debugging tips for you:
    www.8052.com/.../120313
    www.techonlineindia.com/.../Developing_a_good_bedside_manner.aspx
  • And of course - your code could fail to react to the ISR fast enough, resulting in a character being lost.
