Hi Iam trying to start a new project based on STM32F105VC , I opened Uv4 then new project, I write juts very small code for test , it has two files main.c and init.c when i compile them I get the following error , t1.axf: Error: L6218E: Undefined symbol GPIO_Init (referred from intiports.o). t1.axf: Error: L6218E: Undefined symbol GPIO_StructInit (referred from intiports.o). t1.axf: Error: L6218E: Undefined symbol RCC_APB2PeriphClockCmd (referred from intiports.o). couid you help to solve this issue
thank you
#include <stm32f10x_cl.h> //#include <STM32_Reg.h> //#include <stm32f10x_lib.h>
//--- void delay_1sec() { long temp=0xffff; long i; for(i=0;i<300;i++) { while(temp--); temp=0xffff; }
//---------- void SysTick_Handler (void) { static unsigned long ticks ; static unsigned long timetick;
if (ticks++ >= 99) { /* Set Clock1s to 1 every 1 second */ ticks = 0;
//--------------------------- int main(void) {
SystemInit(); //SysTick_Config(SystemFrequency/100); /* Generate interrupt each 10 ms */ //------------------test routines ) init(); while(1);
#include <stm32f10x_lib.h> // STM32F10x Library Definitions
//#include <stm32f10x_gpio.h> //#include <stm32f10x_gpio.h>
#define switch GPIO_Pin_11
GPIO_InitTypeDef GPIO_InitStructure; /* CAN_InitTypeDef CAN_InitStructure; CAN_FilterInitTypeDef CAN_FilterInitStructure; CanTxMsg TxMessage; */ //----- void init() {
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); GPIO_StructInit(&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = switch ; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; GPIO_Init(GPIOA, &GPIO_InitStructure);
For documentation on using Keil's ARM products, see: http://www.keil.com/support/man_arm.htm In particular, http://www.keil.com/support/man/docs/gsac/
For documentation on using ST's Firmware library, see the ST Site.
Note that the ST Firmware library includes example Keil projects...
1) Use of a library requires a library - not just the inclusion of header files.
2) Why do you think a busy loop is a working solution for creating 1 second delays?
3) Did you read the documentation as carefully as you read the posting instructions for posting source code?
4) What are the most common things to check when the linker complains about missing symbols?
