XC164CM-16F and uVision3 V3.50b
we have bought an XC164CM Easy Kit Board with an XC164CM-16F from Infineon. In uVision3 V3.50b, which is supplied with the CD of Infineon, the device "XC164CM-16F" cannot be found under "Options for Target -> Device", only "XC164CM-8F" and "XC164CM-4F" are listed. Which version of uVison3 should support "XC164CM-16F"?
Thanks in advance
Senmeis
  • Did you get anywhere with your problem? I've just received the same board and been having "fun" getting it to work. Gave up on Seven x64 and now working in an XP virtual machine and at least the drivers appear to be working now.
