87C515MB2/MC2 interrupt confusion
I'm working on a application where UART1 is getting a continuous stream of data. I parse it and use some parts for the D2A and other parts are "translated" and sent to UART0.
Most of the ISR code in the project comes from other projects I written in the past.
The following init code is called early in main(). The problem is that any combination of two of timer0, uart0 and uart1 works correctly. As soon as I add the third my timer0 ISR fails. I have used this chip only once before and that project has been in production for over a year. The other project also uses both UARTs but not at the same baud rate and not with the "intensity" of data.
static void Initialize8032( void )
   //    Set up on-board timers.
   //    Timer 0 is used as the system clock.
   //    Timer 1 is used to time fsp protocol related parameters
   //    Timer 2 is used as the UART0 baud rate generator (no interrupt)
   // stop timers 0 & 1
   TMOD = 0x11;          // timers 0 and 1 are 16-bit, manual reload
   TL0 = ( -10 * ONE_MSEC & 0x00ff );
   TH0 = ( -10 * ONE_MSEC & 0xff00 ) >> 8;
   TCON = 0x15;         // Start timer 0 only;, external ints are EDGE triggered.
                        // TR0 = 1;
                        // IT0 = 1;
                        // IT1 = 1;
   // Configure internal serial port and baud rate generator and enable the
   // serial port interrupt.  The onboard UART is used to communciate with
   // the scorer.
   //    RCAP2 baud rate equation:
   //       RCAP2(H,L) = 65536 - (Osc Freq)/((32*baud rate))
   // in X2 Mode:
   //       RCAP2(H,L) = 65536 - (Osc Freq)/((16*baud rate))
   S0CON = 0x40;           // Mode 1, 8-bit UART, receive disabled
   T2CON = 0x30;           // Turn off baud rate generator
#ifdef MC2
   RCAP2L = 0xB8;          // 9600 baud @ 11.059 Mhz 6 clocks
   RCAP2H = 0xFF;
#else
   RCAP2L = 0xEE;
   RCAP2H = 0xFF;
#endif
   T2CON = 0x34;           // Turn on baud rate generator
   S0CON = 0x50;           // Mode 1, 8-bit UART, receive enabled
   IP0  =  0x00;
   IP0H =  0x00;
   IP1  =  0x05;
   IP1H =  0x05;
   IEN0 =  0x92;
   IEN1 =  0x01;
void InitializeUART1( baud_rates_t baud )
   // Lookup table - translates "device_baud_rates_t" to actual value for BRGR0 and BRGR1
   static uint16_t code BaudRateDL[] = {
   0x8E00,  // DEVICE_BAUD_110    TODO: UNTESTED
   0x88B5,  // DEVICE_BAUD_300    TODO: UNTESTED
   0x2400,  // DEVICE_BAUD_1200
   0x11f0,  // DEVICE_BAUD_2400
   0x08F8,  // DEVICE_BAUD_4800
   0x0470,  // DEVICE_BAUD_9600
   0x0238,  // DEVICE_BAUD_19200
   0x011C,  // DEVICE_BAUD_38400
   0x008F,  // DEVICE_BAUD_57600         TODO: WRONG VALUE
   0x0095   // DEVICE_BAUD_115200 TODO: WRONG VALUE
   // Setup UART1 as Mode 1. It can only use the Internal Baud rate Generator (IBRG).
   S1STAT = 0x20;
   // The IBRG must be disabled before BRG0 and BRG1 can be loaded.
   BRGCON = BRGCON & ~0x01;
   S1CON = 0x40;
   BRGR0 = (uint8_t)(BaudRateDL[ baud ] & 0xff);
   BRGR1 = (uint8_t)(BaudRateDL[ baud ] >> 8);
   // The IBRG must be turned back on
   BRGCON |= 0x01;
   REN_1 = 1;
Do you have any thoughts on the problem or a recommendation of a currently available emulator?
