FILE operations for MCB 2300
I am working on MCB 2300 kit (NXP2378 Processor). My application requires to pass an image as input to the program and I need to open that image in write mode. I have tried using fopen (filename,"w") but it throws me the following error
Test.axf: Error: L6200E: Symbol __stdout multiply defined (by stdio_streams.o and retarget.o).
Please let me know how I can open some files for processing them in Keil uVison4.
Thanks in advance
Regards,
Pavan
  • "Error: L6200E: Symbol __stdout multiply (sic) defined (by stdio_streams.o and retarget.o)."
    The use of "multiply" here is not very good.
    What they mean is that the symbol __stdout has multiple definitions: one in stdio_streams.o, and another in retarget.o
    You need to work out which one to keep, and which to remove.
    Have you studied the documentation on "retargetting"?
    ("retargetting" is the process necessary to adapt the generic things like stdout to the specifics of your particular system)
  • Thanks for your reply. I have understood that _stdout has multiple definitions in retarget.o and stdio_streams.o
    When I tried to compile by removing one of the definition in retarget file it is giving compilation error as:
    Test.axf: Error: L6915E: Library reports error: __use_no_semihosting_swi was requested, but _sys_open was referenced
    My requirement here is to take an image as input and read the data in that image pixel by pixel and then process it.
    I have realised that I have to write file system in the stack if I have to use file operations like fopen(), fclose() etc., But I am not sure how to go ahead
    Please let me know how to take things further.
    Regards,
    Pavan
  • Hold on. Depending on what packages you have bought licenses for, Keil have support for flash file systems.
    If you are going to store the file on the stack - this implies RAM - then you can drop the file system and just reserve a RAM buffer for the data.
