I am just getting started in coding the cypress FX2 in C. I was trying a very simple, port toggle example code. But I get the following error "FX2REGS.H(38): error C129: missing ';' before 'GPIF_WAVE_DATA'"
I haven't changed the FX2REGS.H, its as is from the INC folder. I searched for the error, keil online database says, it might be due to a missing ";" in the previous line. Here's the part of the code that's causing the error (line 8 here).
#ifdef ALLOCATE_EXTERN #define EXTERN #define _AT_ _at_ #else #define EXTERN extern #define _AT_ ;/ ## / #endif EXTERN xdata volatile BYTE GPIF_WAVE_DATA _AT_ 0xE400; EXTERN xdata volatile BYTE RES_WAVEDATA_END _AT_ 0xE480;
HUH?
This is what the comments say before the defines
// The Ez-USB FX2 registers are defined here. We use FX2regs.h for register // address allocation by using "#define ALLOCATE_EXTERN". // When using "#define ALLOCATE_EXTERN", you get (for instance): // xdata volatile BYTE OUT7BUF[64] _at_ 0x7B40; // Such lines are created from FX2.h by using the preprocessor. // Incidently, these lines will not generate any space in the resulting hex // file; they just bind the symbols to the addresses for compilation. // You just need to put "#define ALLOCATE_EXTERN" in your main program file; // i.e. fw.c or a stand-alone C source file. // Without "#define ALLOCATE_EXTERN", you just get the external reference: // extern xdata volatile BYTE OUT7BUF[64] ;// 0x7B40; // This uses the concatenation operator "##" to insert a comment "//" // to cut off the end of the line, "_at_ 0x7B40;", which is not wanted.
Where does it say that after preprocessor expansion of the _AT_ macro, the syntax will still be valid?
I have no idea. I am just getting started in C. What exactly is wrong here? The #define _AT_ ?
Try using the "PREPRINT" compiler directive and examine the preprocessor output.
http://www.keil.com/support/man/docs/c51/c51_cm_ifile.htm
well, I need more help.
I tried using preprint in debug. FX2REGS.H PREPRINT
Is that correct? I get "error34: undefined identifier"
I have no idea. I am just getting started in C. You need to read a bit more before you start banging the keys. There are many good books about C, my favorite is Kochan: programming in ANSI C
If, as you say, you are just getting started in C, get your feet wet writing code for the PC and then, when you have the basics down pat, have a go at the micros
Let me rephrase: I am getting started in embedded C. I am in no way an expert on C. But I have coded in C on PC, not Microcontrollers. All my uC was in assembly.
"I tried using preprint in debug. FX2REGS.H PREPRINT"
Compile the C source file(s) that include FX2REGS.H.
I get the same error "*** error 34: undefined identifier"
Do you actually understand what the 'C' preprocessor is, and what it does?
If not, it's time to go back to the 'C' textbook; this is standard stuff - nothing peculiar to C51.
