Hi all,
I tried compiling some sanity-checking example code on an evaluation copy I installed today and got some unexpected results; seemingly no matter what I set the code optimization level to (using the C51 tab in the Options for Target dialog) I get very little optimization in the object code - less than I'd expect, anyhow.
The code I've been testing with is as follows:
static res; void unused() { res = 2 * 2; } int main() { int i =2 , j=3, k=4; i *=i * i; k = (j * j) * (j * j) * i; res = k; return k; }
I expected this to basically optimize away to simply MOV a constant into place. Also, I expected the unused function to be eliminated. I'm not generally seeing this - the unused function is present when I view the assembly output in the debugger. There are multiplies still in the code, although it might have elimated one or two of them.
Am I missing something here? Changing the optimization level does seem to have some effect on the size of the binary produced, so it's doing something. Are there more switches somewhere I need to flip?
I feel your pain. At some point I just stopped looking at the code C51 produces - it was too much to bear. It appears that in terms of compiler technology C51 is stuck in the distant past. You certainly would expect a lot more from a modern compiler...
C51 doesn't claim to do "unused function removal".
I think there's an LX51 Linker option to do it - but you don't get that in the free Eval.
If this is a bona fide evaluation of the tools, you should discuss this with Keil sales (or your distributor)
