the design has 17 channels 500mw each ... Group ON .... Group OFF ... channels with memory for previous state at power up and without memory ... separate black buttons for ON and OFF .... Works with SONY remote control and LG DVD .... indicator power blue LED flashing {saving power} ..... all modifications for definite purpose are possible ........ but when powered the LED goes on but no flash ..... code is good but it will not work .... code at http:\\www.coredump.com\userfile_2538197576a767b ... plz look.
Most people don't feel comfortable following links out in the etherworld.
Post the source for a minimalistic application that fails.
By the way - what have you done to try to figure out what is wrong?
Is the program running but just failing to flash the LED, or do you have a lock-up somewhere?
IF it were good, it would work; Since it doesn't work, it can't be good - can it?!
