I am intending to use an Atmel AT89LP6440 in a new design. I noticed that this device does not show up in the supported devices list. The chip met the project requirements: non-volatile data memory, plenty of needed I/O pins, SPI/TWI, etc. Any suggestions? Thanks for any help sent!
All 8051s share the same instruction set - so the compiler will work.
the "support" mostly refers to simulation, having ready-made headers & startup code, etc.
Thanks so much for your input. However, how does the compiler know much built in memory, etc. the unsupported device has?
You tell it!
See: http://www.keil.com/support/man/docs/uv4/uv4_dg_target51.htm
Also: http://www.keil.com/support/man/docs/uv4/uv4_ca_cpu_ndatabase.htm
Thanks Andy for all your help! Will give a go now.
