MCB251 evaluation board
hi,
i'm having troubles to connect the keil uVision3 V3.8
to the mcb251.
i'm using the following configuration:
IC1 -> AT89C51RE2
IC4 -> empty
com1 , 38400 , using 24Mhz crystal
RTS: active , DTS: active
all cache option is on
serial interupt is on
Monitor 51 identification: Not Connected !
jumper setting on MCB251:
ext_uart & SRC/D2 & A17 is OFF, all others is ON
EA is connected between 1-2
RS232 cable is connected to INT RS232 on MCB251.
please advice
nir
0
