Only one question please What is the definition of mem_test() function in TCPnet manual
void send_data (void) { static const U8 rem_IP[4] = {192,168,0,100}; U8 *sendbuf; if (wait_ack == __TRUE) { return; } if (mem_test (localm[NETIF_ETH].IpAdr, 0, 4) == __TRUE) { /* IP address not yet assigned by DHCP. */ return; } if (bindex < 128) { sendbuf = udp_get_buf (512); for (i = 0; i < 512; i += 2) { sendbuf[i] = bcount >> 8; sendbuf[i+1] = bcount & 0xFF; } udp_send (udp_soc, rem_IP, 1000, sendbuf, 512); } }
Is it a member of stdio.h library? I can not address it anywhere even on google... Thanks kom
It's defined in net_config.h as:
extern BOOL mem_test (void *sp, U8 val, int len);
Looking at the context of where you've taken it from, I would suspect that it is checking a block to see if it all contains a specific value; i.e., all IP address would be zero until DHCP had aquired something useful.
It appears to be undocumented.
A site search for it finds only the above code example at www.keil.com/.../rlarm_tn_using_udp_dhcpen.htm
Yes ...
<rant> And because Keil don't supply the source code to their TCP library (at least, not at a reasonable cost) you can't easily determine what it does. </rant>
