Hi, In startup code the first instruction is:
org 0x00 ldr pc,[pc,#24]
and at offset address 0x20:
org 0x20 dc32 ?cstartup
What I don't understand here is, after the first instruction shown above how come PC holds 0x20 and not 0x18?? Isn't PC supposed to be pointing to the current instruction being executed? If that's the case after the above step shouldn't PC be (0x00 + #24)= (0x00 + 0x18) = 0x18 ??
Thanks.
No. PC is always 8 bytes ahead!
the reason for this is the processor's pipeline. check you architecture manual.
PC is always 8 bytes ahead! You mean PC points to the (next) instruction to be fetched and not the current instruction being executed. This is what even I have always heard.
I tried to make sense of it:
Pipeline------Addr---Instruction Status --------------------------------- to Execute-----0-----ldr pc, [pc,#24] to Decode------4-----xyz_instr to Fetch-------8-----xyz_instr1
So PC here (in the ldr instruction) is 0x0000 0008 (Again, if it were THUMB mode then PC would be 0x0000 0004) Hence, PC + #24 = PC + 0x18 = 0x08 + 0x18 = 0x20
Thanks for your support :)
