uVision debugger crashes as soon as i press run
Former Member
Former Member
Hi All
I have something strange with my uVision4 (4.01).
I compiled a program, loaded it on my board (LPC1700) and started the debugger. The debugger started briefly but almost immediately returned to the compiler again.
I tried the usual, restarting uVision, no luck, restarting windows, no luck
Then I removed the tick at "Run to Main" and then the debugger staid. But single stepping caused the same effect, return to compiler, after 5 steps.
Then I loaded Blinky just to witness that Binky did exactly the same. Now I this slowly drives me crazy.
I noticed there was an update (4.03) and I loaded that. My uLink needed a firmware update after that so i considered that a good sign. But still, no luck. It still crashes.
I checked a lot a entries in the forum, i removed memory windows, changed the USB connections but it is still the same. I am pretty desperate now.... Someone with a good idea out there?
  • Former Member
    0 Former Member
    Solved.....
    I noticed that (very briefly) the message "cannot access memory" popped up in the message window. I started looking for it and found an entry in the forum for a different CPU but that did the trick.
    When you have a memory window open and there is an address in there, clear the address field, close the window and then close uVision. Then start it again and the problem is solved.
  • There is an option in the Debug settings to control whether uVision "remembers" previous settings - like memory watches.
    Presumably, clearing this would also have solved your problem?
  • Former Member
    0 Former Member in reply to Andy Neil
    Hi
    Yep it would have I guess. But it doesn't, my problem just returned. It worked for one debugging session but now it crashes again. I stepped through the program and noticed that it already crashes after the 5th step. the message "Cannot access memory" pops up and then I return to the compiler.
    0x1FFF0080 F8DF4018 LDR.W r4,[pc,#24] ; @0x1FFF009C
    0x1FFF0084 F8DF5010 LDR.W r5,[pc,#16] ; @0x1FFF0098
    0x1FFF0088 6826 LDR r6,[r4,#0x00]
    0x1FFF008A EA050606 AND r6,r5,r6
    0x1FFF008E 6026 STR r6,[r4,#0x00] <== It crashes here
    0x1FFF0090 F8DFF000 LDR.W pc,[pc,#0] ; @0x1FFF0094
    0x1FFF0094 0201 LSLS r1,r0,#8
    0x1FFF0096 1FFF SUBS r7,r7,#7
    I changed the board, the uLink and everything, just nothing helps.
  • The problematic instruction is part of the NXP ROM bootloader and writes to a special memory location which disables debug pins. Therefore after debugger steps over it the communication is lost.
    Either skip this instruction when single stepping or run through the bootloader.
  • Robert,
    Could you please elaborate a little more on this issue? The circumstances described by you and the OP and the instruction involved look strangely familiar to the source of my current headache (see here:http://www.keil.com/forum/docs/thread16421.asp). Thank you.
  • Former Member
    0 Former Member in reply to Tamir Michael
    Hi
    With the help of Alex from Keil I solved the issue.
    The NXP jtag tool for the LPC17xx needs the flag SWJ to be set. The Field Port must be on SW. Then it works. Don't ask why, I have no idea.
    Thanks for all the replies
    Walter
