ID look up table LPC1768
Hey,
I tried to generate a look up table for my Can Controller but I have a lot of troubles.
In the user manual on page 374 stands that the SFF_sa is disabled when the Value is <0 . But on page 395 you can see in the example, that they start at 0x00 ... is that right?
I program it this way, but i can not receive a special message:
void CAN_SetACCF_Lookup( void )
  uint32_t address = 0;
  uint32_t ID_high, ID_low;
  // Set explicit standard Frame
  LPC_CANAF->SFF_sa = address;
  ID_low = (0x001 << 29) | (0x2C1 << 16) | (1<<27);
  ID_high = (0x001 << 13) | (0x320 << 0) | (1<<11);
  *((volatile uint32_t *)(LPC_CANAF_RAM_BASE + address)) = ID_low | ID_high;
  address += 4;
  // Set group standard Frame
  LPC_CANAF->SFF_GRP_sa = address;
  // Set explicit extended Frame
  LPC_CANAF->EFF_sa = address;
    // Set group extended Frame
  LPC_CANAF->EFF_GRP_sa = address;
  // Set End of Table
  LPC_CANAF->ENDofTable = address;
  return;
  • Empty tables are disabled, i.e. if start and end address have the same value.
    SFF_sa is start address for standard-frame rules. If SFF_sa = 0, means that the table before (FulLCAN) is empty, and hence disabled.
    There is no pointer for start of FulLCAN, since that table has the hard-coded start address 0.
  • ah okay thanks =)
    i also have another question, when i receive a message i generate an interrupt and store my received data and then release the receive buffer to avoid a data overrun.
    i did it this way:
    [pre]
    uint32_t * pDest; /* initialize destination pointer */ pDest = (uint32_t *)&MsgBuf_RX1; *pDest = LPC_CAN1->RFS; /* Frame */
    pDest++; *pDest = LPC_CAN1->RID; /* ID */
    pDest++; *pDest = LPC_CAN1->RDA; /* Data A */
    pDest++; *pDest = LPC_CAN1->RDB; /* Data B */
    CAN1RxDone = TRUE; LPC_CAN1->CMR = 0x01 << 2; /* release receive buffer */ return;
    [/pre]
    But when I receive a valid message always a data overrun occurs, i dont't know why because i think i store it fast enough ...
