I have one question about the machine code of bit variable in ?C_INITSEG and normal function
Assume bit variable PASS is declared and defined:
bit PASS=0;
After starting Debug Session I can see the machine code for PASS=0 and PASS=1 as follows:
(For PASS=1) D234 SETB PASS(0x26.4) (For PASS=0) C234 CLR PASS(0x26.4) * where C2 is highByte and 34 is lowByte
Thus I guess: 0x34 means PASS variable and C2/D2 for CLR/SETB
But if I did not assign initial value to PASS like below:
bit PASS; // no initialization compared with above
Then I found C134 is absent in ?C_INITSEG SEGMENT(due to not initializing PASS variable...)
It seems: C134 for "PASS=0" in ?C_INITSEG and C234 for "PASS=0" in normal function... Why does "PASS=0" have 2 different machine code representation?
