..\display.h(72): warning: #231-D: declaration is not visible outside of function
I got message when I included a header file containing this line:
void DISPLAY_string_date_time(const struct tm * tim, DISPLAY_MSG * p_message);
I found the problem - I hadn't included <time.h> in the two cases that caused the warning.
After a lot of searching for what this warning means, I can't find any explanation.
Can anyone translate what the compiler is saying?
  • Surely, it doesn't need any translation?
    But it is impossible to guess which declaration, and which function it is referring to without seeing the relevant source line(s)!
    Are you sure that you included the header at an appropriate position...?
  • I wouldn't ask for a translation if I didn't need one.
    I know what the error was caused by. It was missing the definition of the tm struct in <time.h>.
    What I don't understand is why I wouldn't just get an undefined reference error.
    I would like to understand how the compiler interpreted this to end up with this error.
  • In order to understand that, it would be necessary to see exactly what you gave to the compiler to cause it.
    As you haven't shown that, it is impossible to tell!
    "I know what the error was caused by. It was missing the definition of the tm struct in <time.h>."
    When you've had one error like that, it almost certainly means that the compiler is "out-of-sync" with your source text from that point on - it is therefore pointless worrying about subsequent errors, as they are almost certainly affected by the initial error.
    If you've fixed the "tm struct" error, and then all the other messages just "magically" disappear, that confirms that they were all just consequences of that one error.
    Move along now - nothing (more) to see here...
  • I get that you can't explain it.
    I'm still interested though.
  • I would really be interested too. I can't directly see what source code error that would motivate the error message.
    Something declared within a function is intended to be only visible within the function, so there should not be any warning.
    Do you have any data types declared in any of your functions? In case the compiler saw tm being declared somewhere else in the code, it might have decided to be overly clever and warn that your undefined global tm use could not be matched with the local definition int saw somewhere else. But in that case, the compiler should have been so clever that it showed the other line number too.
  • Not without seeing your actual source code, of course.
    But I very much suspect that it is as I suggested: your initial error(s) due to the missing header have thrown the compiler so far out-of-sync with your source text that it is giving apparently meaningless messages.
    Sometimes it can get so grossly out-of-sync that it will actually crash!
    If you really want to pursue it, you need to look at the point of the very first error and ask yourself what the compiler is assuming was there - having rejected what you actually wrote as invalid, and so on...
    But, as I said, it is pointless - just fix the original error, and that will naturally fix all the consequent errors!
  • That's probably because nothing has directly caused it; it is probably caused "indiectly" as a result of the compiler getting out-of-sync with the source text because of the original error(s) due to the missing header(s).
  • Here is the code. I have included the relevant bits of what's in the include file.
    To clarify one more time, there are no errors. It is only a warning. It compiles and runs. But I can't check in code with warnings, so I had to find it.
    #include <time.h>
    ...more
    struct tm {
        int tm_sec;   /* seconds after the minute, 0 to 60
                         (0 - 60 allows for the occasional leap second) */
        int tm_min;   /* minutes after the hour, 0 to 59 */
        int tm_hour;  /* hours since midnight, 0 to 23 */
        int tm_mday;  /* day of the month, 1 to 31 */
        int tm_mon;   /* months since January, 0 to 11 */
        int tm_year;  /* years since 1900 */
        int tm_wday;  /* days since Sunday, 0 to 6 */
        int tm_yday;  /* days since January 1, 0 to 365 */
        int tm_isdst; /* Daylight Savings Time flag */
        union {       /* ABI-required extra fields, in a variety of types */
            struct {
                int __extra_1, __extra_2;
            struct {
                long __extra_1_long, __extra_2_long;
            struct {
                char *__extra_1_cptr, *__extra_2_cptr;
            struct {
                void *__extra_1_vptr, *__extra_2_vptr;
    ...more
    #include "display.h"
    ...more
    typedef struct
        uint32_t    x;
        uint32_t    y;
        uint32_t    size;
        uint32_t    font;
        uint8_t     text[24];
    } DISPLAY_MSG;
    ...more
    If I comment out <time.h>, I get the warning and a clean compile. With <time.h> in I don't get the warning.
    I don't understand why I wouldn't just get an "Identifier undefined" type of error.
    The reason I'm willing to try to find an answer is that I spent a lot of time searching for an explanation. If I understood why I got that error this time, I might find it faster next time. It would have taken 10 seconds to find if I had got an "Identifier undefined" error.
  • To clarify, there are no errors. I get one warning. The compiler has definitely not lost the syntax trail.
  • I don't understand why I wouldn't just get an "Identifier undefined" type of error.
    The function prototype declaration does not require knowledge about the size of "struct tm", so is allowed without the complete structure type definition being in scope. An error diagnostic would be unwarranted in this case (but compilers are allowed to warn about anything).
  • You are right.
    The compiler makes a difference between:
    int function(struct tm* t);
    and
    struct tm;
    I haven't thought about this case before. I always have the second alternative, if I need to make use of a struct or class pointer without letting the header file see the full definition.
  • After a lot of searching for what this warning means, I can't find any explanation.
    You've already found all essential elements of the explanation. You just haven't connected the dots yet.
    The problem is in that header you included: it can't stand on its own feet. This header uses struct tm, which is a type defined in <time.h>. So it really should #include <time.h> to have it available.
    Since it didn't, the "struct tm *" in that function's argument list is a forward declaration of type struct tm, but one that only applies to the function prototype it's in. That's surely not what it was supposed to mean. I.e. the code doesn't do what its author is most likely to have intended. The compiler is absolutely correct warning you about it.
    No. There are situations where this happens, and causes all kinds of weird messages from the compiler. But this is not one of them.
    The warning message under discussion is fully justified, and its text points exactly at the problem.
  • Thanks Dan.
    That makes perfect sense now. Life would be simpler if there were a place where the error message was explained with the two paragraphs you just wrote.
  • Yes, indeed - this has been noted before!
    eg, my post of 4-Sep-2009 17:22 GMT in this thread: http://www.keil.com/forum/docs/thread15484.asp
