LPC3250 and init of SDRAM (MT48LC2M32B2 )
Hello
I m trying to initialise a MT48LC2M32B2 SDRAM coming from MICRON with a LPC3250.
Here is my function:
void initSDRAM()
    int dummy = dummy;
                SDRAMCLK_CTRL = 0x0;      //validation SDRAM HCLK
                MPMCAHBControl0 = 0x1;
                MPMCAHBControl2 = 0x1;
                MPMCAHBControl3 = 0x1;
                MPMCAHBControl4 = 0x1;
                MPMCAHBTimeout0 = 0x0100;
                MPMCAHBTimeout2 = 0x0190;
                MPMCAHBTimeout3 = 0x0190;
                MPMCAHBTimeout4 = 0x0190;
            SDRAMCLK_CTRL = 0x72800;      //slow slewrate for 2V8 IO and 2.5ns delay
                MPMCControl     =  0x1;       // validation EMC
                MPMCConfig  = 0x0;        // little endian mode
                MPMCDynamicConfig0 = 0x00004300; // 64MB, 2Mbx32, 4 banks, row=11, column=8
                MPMCDynamicRasCas0 = 0x00000303; // Default setting, RAS latency 3 CCLKs, CAS latenty 3 CCLKs.
                MPMCDynamicReadConfig = 0x11;    // Command delayed strategy
                MPMCDynamicRP     = 2;          // command period: 3(n+1) clock cycles
                MPMCDynamicRAS    = 3;          // RAS command period: 4(n+1) clock cycles
                MPMCDynamicSREX   = 7;          // Self-refresh period: 8(n+1) clock cycles
        MPMCDynamicWR     = 1;          // Write recovery: 2(n+1) clock cycles
            MPMCDynamicRC     = 7;              // Active to Active cmd: 8(n+1) clock cycles
                MPMCDynamicRFC    = 7;          // Auto-refresh: 8(n+1) clock cycles
                MPMCDynamicXSR    = 7;          // Exit self-refresh: 8(n+1) clock cycles
            MPMCDynamicRRD    = 1;              // Active bank A->B: 2(n+1) clock cycles          //ini : 2
                MPMCDynamicMRD    = 2;          // Load Mode to Active cmd: 3(n+1) clock cycles
                MPMCDynamicCDLR   = 1;
        MPMCDynamicRefresh = 50;        //50 x 16CCLKs=800CCLK=7us between SDRAM refresh cycles
                wait(1);
                //envoi d'un NOP
                MPMCDynamicControl = 0x00000193;
        wait(20);  //delai de 100us mini
        // envoi d'un PRECHARGE
        MPMCDynamicControl = 0x00000113;
                MPMCDynamicRefresh = 8;
                wait(1);
                wait(1);
                MPMCDynamicControl = 0x00000093;
                // envoi de la commande de programmation du MODE REGISTER
                dummy = *((volatile int *)(SDRAM_BASE_ADDR | (0x33 << 12)));
                //send NOP
                // Send command: NORMAL
                MPMCDynamicControl = 0x00000001;  //0x01 because code is in NOR FLASH
                wait(20);     //         1 = 10 us
After this was executed, I can see the refresh of the SDRAM. But unfortunately, when I write something, I can t read it, even if in the debugger.
The frequency of the HCLK is 104 MHz, the same as the EMC clk.
Can someone help me with this problem?
Thanks in advance
Best Regards
Yuga
