Hi, I have a problem with my STR9 when I try to use USB library (VirtualCOM) and RTX at the same time. I'm starting from 2 projects running well: the first one uses RTX (Blinky_RTX is a Keil example) and the second one opens a VirtualCOM. The problem occurs when i try to merge them: if I add the RTX on the VirtualCOM project, the micro does not start the operative system. I think the problem is in the sturt-up code but I don't know how to resolve it... Can someone help me??
Thanks in advance
Hi, is your SWI_Handler OK?
Yes, I commented the line and I imported it... It seems an Interrupt problem couse it goes in UndefinedHandler...
IF LEH_SETUP = 0
IMPORT SWI_Handler
UndefHandler B UndefHandler ;SWIHandler B SWIHandler ; Part of RTL PAbtHandler B PAbtHandler DAbtHandler B DAbtHandler IRQHandler B IRQHandler FIQHandler B FIQHandler
The probel is that the .s files are very different between the Blinky_RTX project given by Keil, and the VirtualCom example given by STMicroelectronics (it includes also a vector.s). It's not easy merge them....
Those were my steps. I downloaded the virtualCOM example for STR9 from ST. I compiled and flashed: it runs. I added RTXConfig.c and i icluded RTL.h into my main: it compiles and runs. I create init task in my main: os_sys_init (init) It compiles (no warnings) but crashes and debugging i can't understand the errors couse when i stop the micro it is always in different and strange code position... I really don't know what happens!!
Share the swi.s file which you are using
The example uses two .s files. This is the first one:
Debug_Mode EQU 0
; --- Standard definitions of mode bits and interrupt (I & F) flags in PSRs
Mode_USR EQU 0x10 Mode_FIQ EQU 0x11 Mode_IRQ EQU 0x12 Mode_SVC EQU 0x13 Mode_ABT EQU 0x17 Mode_UND EQU 0x1B Mode_SYS EQU 0x1F ; available on ARM Arch 4 and later
I_Bit EQU 0x80 ; when I bit is set, IRQ is disabled F_Bit EQU 0x40 ; when F bit is set, FIQ is disabled
UND_Stack_Size EQU 0x00000000 SVC_Stack_Size EQU 0x00000008 ABT_Stack_Size EQU 0x00000000 FIQ_Stack_Size EQU 0x00000020 IRQ_Stack_Size EQU 0x00000100 USR_Stack_Size EQU 0x00000400
ISR_Stack_Size EQU (UND_Stack_Size + SVC_Stack_Size + ABT_Stack_Size + \ FIQ_Stack_Size + IRQ_Stack_Size)
AREA STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem SPACE USR_Stack_Size __initial_sp SPACE ISR_Stack_Size Stack_Top
Heap_Size EQU 0x00000200
AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit
; --- STR9X SCU specific definitions
SCU_BASE_Address EQU 0x5C002000 ; SCU Base Address SCU_SCR0_OFST EQU 0x00000034 ; System Configuration Register 0 Offset
; --- STR9X FMI specific definitions
FMI_BASE_Address EQU 0x54000000 ; FMI Base Address FMI_BBSR_OFST EQU 0x00000000 ; Boot Bank Size Register offset FMI_NBBSR_OFST EQU 0x00000004 ; Non-boot Bank Size Register offset FMI_BBADR_OFST EQU 0x0000000C ; Boot Bank Base Address Register offset FMI_NBBADR_OFST EQU 0x00000010 ; Non-boot Bank Base Address Register offset FMI_CR_OFST EQU 0x00000018 ; Control Register offset
FMI_SETUP EQU 1 FMI_CR_Val EQU 0x00000018 FMI_BBSR_Val EQU 0x00000004 FMI_BBADR_Val EQU 0x00000000 FMI_NBBSR_Val EQU 0x00000002 FMI_NBBADR_Val EQU 0x00080000 FLASH_CFG_Val EQU 0x00000000
;--------------------------------------------------------------- ; Reset Handler ;---------------------------------------------------------------
PRESERVE8
; Area Definition and Entry Point ; Startup Code must be linked first at Address at which it expects to run.
AREA Init, CODE, READONLY ARM EXPORT Reset_Handler Reset_Handler LDR pc, =NextInst NextInst ; ------------------------------------------------------------------------------ ; Description : This delay is added to let JTAG debuggers able to connect ; to STR91x micro then load the program even if a previously ; flash code is halting the CPU core. This may happen when the ; flash content is corrupt by containing a "bad" code like entering ; soon to IDLE or SLEEP Low power modes. ; When going to production/Release code and to remove this Start-up ; delay, Please comment the "Debug_mode" define above. ; ------------------------------------------------------------------------------ IF Debug_Mode = 1 MOV r0, #0x4000 Loop SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 BNE Loop ENDIF
; ------------------------------------------------------------------------------ ; Description : Enable the Buffered mode. ; To use buffered mode access you have to uncomment Buffered ; define on the 91x_conf.h file ; ------------------------------------------------------------------------------
MRC p15, 0, r0, c1, c0, 0 ; Read CP15 register 1 into r0 ORR r0, r0, #0x8 ; Enable Write Buffer on AHB MCR p15, 0, r0, c1, c0, 0 ; Write CP15 register 1 ;------------------------------------------------------------------------------ ; Description : Write Buffer in ITCM may cause the Flash “write then read” ; command order reversed and cause flash error. ; To maintain the right order, bit 18 (Instruction TCM order bit) ; in the Configuration Registers of the ARM966E-S core must be set. ; ------------------------------------------------------------------------------
MOV r0, #0x40000 MCR p15,0x1,r0,c15,c1,0
;------------------------------------------------------------------------------ ; Description : FMI Registers configuration depending on the Flash size selected, ; and the boot bank. ; ; After reset, the application program has to write the size and start ; address of Bank 1 in the FMI_BBSR and FMI_BBADR registers and the size and ; start address of Bank 0 in the FMI_NBBSR and FMI_NBBADR registers. ; ------------------------------------------------------------------------------
LDR R6, =FMI_BASE_Address LDR R7, = FMI_BBSR_Val ; BOOT BANK Size= STR R7, [R6, #FMI_BBSR_OFST] ; (2^BOOT_BANK_Size) * 32KBytes LDR R7, = FMI_NBBSR_Val ; NON BOOT BANK Size = STR R7, [R6, #FMI_NBBSR_OFST] ; (2^NON_BOOT_BANK_Size) * 8KBytes LDR R7, =FMI_BBADR_Val ; BOOT BANK Address MOV R7, R7 ,LSR #0x2 STR R7, [R6, #FMI_BBADR_OFST] LDR R7, =FMI_NBBADR_Val ; BOOT BANK Address MOV R7, R7 ,LSR #0x2 STR R7, [R6, #FMI_NBBADR_OFST]
LDR R7, = 0x19 ; Enable Both banks STR R7, [R6, #FMI_CR_OFST]
; --- Enable 96K of RAM & Disable DTCM & AHB wait-states
LDR R0, = SCU_BASE_Address LDR R1, = 0x0191 STR R1, [R0, #SCU_SCR0_OFST]
; Setup Stack for each mode
LDR R0, =Stack_Top
; Enter Undefined Instruction Mode and set its Stack Pointer MSR CPSR_c, #Mode_UND:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #UND_Stack_Size
; Enter Abort Mode and set its Stack Pointer MSR CPSR_c, #Mode_ABT:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #ABT_Stack_Size
; Enter FIQ Mode and set its Stack Pointer MSR CPSR_c, #Mode_FIQ:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #FIQ_Stack_Size
; Enter IRQ Mode and set its Stack Pointer MSR CPSR_c, #Mode_IRQ:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #IRQ_Stack_Size
; Enter Supervisor Mode and set its Stack Pointer MSR CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #SVC_Stack_Size
; Enter User Mode and set its Stack Pointer MSR CPSR_c, #Mode_SYS IF :DEF:__MICROLIB
EXPORT __initial_sp
ELSE
MOV SP, R0 SUB SL, SP, #USR_Stack_Size
ENDIF
; Enter the C code
IMPORT __main B __main
IF :DEF:__MICROLIB
EXPORT __heap_base EXPORT __heap_limit
ELSE ; User Initial Stack & Heap AREA |.text|, CODE, READONLY
IMPORT __use_two_region_memory EXPORT __user_initial_stackheap __user_initial_stackheap
LDR R0, = Heap_Mem LDR R1, =(Stack_Mem + USR_Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR ENDIF
END
Please follow the posting instructions for how to format source code.
Should look like:
int my_variable;
This is the second one (thankyou very much)
VectorAddress EQU 0xFFFFF030 ; VIC Vector address register address.
EXPORT Vectors
IMPORT Reset_Handler
IMPORT Undefined_Handler IMPORT SWI_Handler IMPORT Prefetch_Handler IMPORT Abort_Handler IMPORT FIQ_Handler
PRESERVE8 AREA Reset, CODE, READONLY ARM Vectors LDR PC, Reset_Addr LDR PC, Undefined_Addr LDR PC, SWI_Addr LDR PC, Prefetch_Addr LDR PC, Abort_Addr NOP ; Reserved vector LDR PC, IRQ_Addr
FIQHandler SUB lr,lr,#4 ; Update the link register. STMFD sp!,{r0-r3,lr} ; Save The workspace plus the current return ; address lr_fiq into the FIQ stack. ldr r0,=FIQ_Handler ldr lr,=FIQ_Handler_end bx r0 ;Branch to FIQ_Handler. FIQ_Handler_end
LDMFD sp!,{r0-r3,pc}^; Return to the instruction following... ; ...the exception interrupt.
;******************************************************************************* ; Exception handlers address table ;*******************************************************************************
Reset_Addr DCD Reset_Handler Undefined_Addr DCD UndefinedHandler SWI_Addr DCD SWIHandler Prefetch_Addr DCD PrefetchAbortHandler Abort_Addr DCD DataAbortHandler DCD 0 ; Reserved vector IRQ_Addr DCD IRQHandler
MACRO SaveContext $reg1,$reg2
STMFD sp!,{$reg1-$reg2,lr} ; Save The workspace plus the current return ; address lr_ mode into the stack.
MEND
MACRO RestoreContext $reg1,$reg2
LDMFD sp!,{$reg1-$reg2,pc}^; Return to the instruction following... ; ...the exception interrupt. MEND
;******************************************************************************* ; Exception Handlers ;*******************************************************************************
UndefinedHandler SaveContext r0,r3 ; Save the workspace plus the current ; return address lr_ und.
ldr r0,=Undefined_Handler ldr lr,=Undefined_Handler_end bx r0 ; Branch to Undefined_Handler.
Undefined_Handler_end RestoreContext r0,r3 ; Return to the instruction following... ; ...the undefined instruction.
;******************************************************************************* ;* Function Name : SWIHandler ;* Description : This function is called when SWI instruction executed. ;* Input : none ;* Output : none ;*******************************************************************************
SWIHandler SaveContext r0,r3 ; Save the workspace plus the current ; return address lr_ svc.
ldr r0,=SWI_Handler ldr lr,=SWI_Handler_end bx r0 ; Branch to SWI_Handler.
SWI_Handler_end RestoreContext r0,r3 ; Return to the instruction following... ; ...the SWI instruction. ;******************************************************************************* ;* Function Name : PrefetchAbortHandler ;* Description : This function is called when Prefetch Abort ; exception is entered. ;* Input : none ;* Output : none ;*******************************************************************************
PrefetchAbortHandler SUB lr,lr,#4 ; Update the link register. SaveContext r0,r3 ; Save the workspace plus the current ; return address lr_abt.
ldr r0,=Prefetch_Handler ldr lr,=Prefetch_Handler_end bx r0 ; Branch to Prefetch_Handler.
Prefetch_Handler_end RestoreContext r0,r3 ; Return to the instruction following that... ; ...has generated the prefetch abort exception.
;******************************************************************************* ;* Function Name : DataAbortHandler ;* Description : This function is called when Data Abort ; exception is entered. ;* Input : none ;* Output : none ;*******************************************************************************
DataAbortHandler SUB lr,lr,#8 ; Update the link register. SaveContext r0,r3 ; Save the workspace plus the current ; return address lr_ abt. ldr r0,=Abort_Handler ldr lr,=Abort_Handler_end bx r0 ; Branch to Abort_Handler.
Abort_Handler_end
RestoreContext r0,r3 ; Return to the instruction following that... ; ...has generated the data abort exception. ;******************************************************************************* ;* Function Name : IRQHandler ;* Description : This function is called when IRQ exception is entered. ;* Input : none ;* Output : none ;*******************************************************************************
IRQHandler SUB lr,lr ,#4 SaveContext r0,r3 LDR r0, = VectorAddress LDR r0, [r0] ; Read the routine address from VIC0 Vector Address register
BLX r0 ; Branch with link to the IRQ handler. RestoreContext r0,r3
LTORG
Debug_Mode EQU 0 ; --- Standard definitions of mode bits and interrupt (I & F) flags in PSRs Mode_USR EQU 0x10 Mode_FIQ EQU 0x11 Mode_IRQ EQU 0x12 Mode_SVC EQU 0x13 Mode_ABT EQU 0x17 Mode_UND EQU 0x1B Mode_SYS EQU 0x1F ; available on ARM Arch 4 and later I_Bit EQU 0x80 ; when I bit is set, IRQ is disabled F_Bit EQU 0x40 ; when F bit is set, FIQ is disabled UND_Stack_Size EQU 0x00000000 SVC_Stack_Size EQU 0x00000008 ABT_Stack_Size EQU 0x00000000 FIQ_Stack_Size EQU 0x00000020 IRQ_Stack_Size EQU 0x00000100 USR_Stack_Size EQU 0x00000400 ISR_Stack_Size EQU (UND_Stack_Size + SVC_Stack_Size + ABT_Stack_Size + \ FIQ_Stack_Size + IRQ_Stack_Size) AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE USR_Stack_Size __initial_sp SPACE ISR_Stack_Size Stack_Top Heap_Size EQU 0x00000200 AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit ; --- STR9X SCU specific definitions SCU_BASE_Address EQU 0x5C002000 ; SCU Base Address SCU_SCR0_OFST EQU 0x00000034 ; System Configuration Register 0 Offset ; --- STR9X FMI specific definitions FMI_BASE_Address EQU 0x54000000 ; FMI Base Address FMI_BBSR_OFST EQU 0x00000000 ; Boot Bank Size Register offset FMI_NBBSR_OFST EQU 0x00000004 ; Non-boot Bank Size Register offset FMI_BBADR_OFST EQU 0x0000000C ; Boot Bank Base Address Register offset FMI_NBBADR_OFST EQU 0x00000010 ; Non-boot Bank Base Address Register offset FMI_CR_OFST EQU 0x00000018 ; Control Register offset FMI_SETUP EQU 1 FMI_CR_Val EQU 0x00000018 FMI_BBSR_Val EQU 0x00000004 FMI_BBADR_Val EQU 0x00000000 FMI_NBBSR_Val EQU 0x00000002 FMI_NBBADR_Val EQU 0x00080000 FLASH_CFG_Val EQU 0x00000000 ;--------------------------------------------------------------- ; Reset Handler ;--------------------------------------------------------------- PRESERVE8 ; Area Definition and Entry Point ; Startup Code must be linked first at Address at which it expects to run. AREA Init, CODE, READONLY ARM EXPORT Reset_Handler Reset_Handler LDR pc, =NextInst NextInst ; ------------------------------------------------------------------------------ ; Description : This delay is added to let JTAG debuggers able to connect ; to STR91x micro then load the program even if a previously ; flash code is halting the CPU core. This may happen when the ; flash content is corrupt by containing a "bad" code like entering ; soon to IDLE or SLEEP Low power modes. ; When going to production/Release code and to remove this Start-up ; delay, Please comment the "Debug_mode" define above. ; ------------------------------------------------------------------------------ IF Debug_Mode = 1 MOV r0, #0x4000 Loop SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 BNE Loop ENDIF ; ------------------------------------------------------------------------------ ; Description : Enable the Buffered mode. ; To use buffered mode access you have to uncomment Buffered ; define on the 91x_conf.h file ; ------------------------------------------------------------------------------ MRC p15, 0, r0, c1, c0, 0 ; Read CP15 register 1 into r0 ORR r0, r0, #0x8 ; Enable Write Buffer on AHB MCR p15, 0, r0, c1, c0, 0 ; Write CP15 register 1 ;------------------------------------------------------------------------------ ; Description : Write Buffer in ITCM may cause the Flash “write then read” ; command order reversed and cause flash error. ; To maintain the right order, bit 18 (Instruction TCM order bit) ; in the Configuration Registers of the ARM966E-S core must be set. ; ------------------------------------------------------------------------------ MOV r0, #0x40000 MCR p15,0x1,r0,c15,c1,0 ;------------------------------------------------------------------------------ ; Description : FMI Registers configuration depending on the Flash size selected, ; and the boot bank. ; ; After reset, the application program has to write the size and start ; address of Bank 1 in the FMI_BBSR and FMI_BBADR registers and the size and ; start address of Bank 0 in the FMI_NBBSR and FMI_NBBADR registers. ; ------------------------------------------------------------------------------ LDR R6, =FMI_BASE_Address LDR R7, = FMI_BBSR_Val ; BOOT BANK Size= STR R7, [R6, #FMI_BBSR_OFST] ; (2^BOOT_BANK_Size) * 32KBytes LDR R7, = FMI_NBBSR_Val ; NON BOOT BANK Size = STR R7, [R6, #FMI_NBBSR_OFST] ; (2^NON_BOOT_BANK_Size) * 8KBytes LDR R7, =FMI_BBADR_Val ; BOOT BANK Address MOV R7, R7 ,LSR #0x2 STR R7, [R6, #FMI_BBADR_OFST] LDR R7, =FMI_NBBADR_Val ; BOOT BANK Address MOV R7, R7 ,LSR #0x2 STR R7, [R6, #FMI_NBBADR_OFST] LDR R7, = 0x19 ; Enable Both banks STR R7, [R6, #FMI_CR_OFST] ; --- Enable 96K of RAM & Disable DTCM & AHB wait-states LDR R0, = SCU_BASE_Address LDR R1, = 0x0191 STR R1, [R0, #SCU_SCR0_OFST] ; Setup Stack for each mode LDR R0, =Stack_Top ; Enter Undefined Instruction Mode and set its Stack Pointer MSR CPSR_c, #Mode_UND:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #UND_Stack_Size ; Enter Abort Mode and set its Stack Pointer MSR CPSR_c, #Mode_ABT:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #ABT_Stack_Size ; Enter FIQ Mode and set its Stack Pointer MSR CPSR_c, #Mode_FIQ:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #FIQ_Stack_Size ; Enter IRQ Mode and set its Stack Pointer MSR CPSR_c, #Mode_IRQ:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #IRQ_Stack_Size ; Enter Supervisor Mode and set its Stack Pointer MSR CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #SVC_Stack_Size ; Enter User Mode and set its Stack Pointer MSR CPSR_c, #Mode_SYS IF :DEF:__MICROLIB EXPORT __initial_sp ELSE MOV SP, R0 SUB SL, SP, #USR_Stack_Size ENDIF ; Enter the C code IMPORT __main B __main IF :DEF:__MICROLIB EXPORT __heap_base EXPORT __heap_limit ELSE ; User Initial Stack & Heap AREA |.text|, CODE, READONLY IMPORT __use_two_region_memory EXPORT __user_initial_stackheap __user_initial_stackheap LDR R0, = Heap_Mem LDR R1, =(Stack_Mem + USR_Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR ENDIF END
VectorAddress EQU 0xFFFFF030 ; VIC Vector address register address. EXPORT Vectors IMPORT Reset_Handler IMPORT Undefined_Handler IMPORT SWI_Handler IMPORT Prefetch_Handler IMPORT Abort_Handler IMPORT FIQ_Handler PRESERVE8 AREA Reset, CODE, READONLY ARM Vectors LDR PC, Reset_Addr LDR PC, Undefined_Addr LDR PC, SWI_Addr LDR PC, Prefetch_Addr LDR PC, Abort_Addr NOP ; Reserved vector LDR PC, IRQ_Addr FIQHandler SUB lr,lr,#4 ; Update the link register. STMFD sp!,{r0-r3,lr} ; Save The workspace plus the current return ; address lr_fiq into the FIQ stack. ldr r0,=FIQ_Handler ldr lr,=FIQ_Handler_end bx r0 ;Branch to FIQ_Handler. FIQ_Handler_end LDMFD sp!,{r0-r3,pc}^; Return to the instruction following... ; ...the exception interrupt. ;******************************************************************************* ; Exception handlers address table ;******************************************************************************* Reset_Addr DCD Reset_Handler Undefined_Addr DCD UndefinedHandler SWI_Addr DCD SWIHandler Prefetch_Addr DCD PrefetchAbortHandler Abort_Addr DCD DataAbortHandler DCD 0 ; Reserved vector IRQ_Addr DCD IRQHandler MACRO SaveContext $reg1,$reg2 STMFD sp!,{$reg1-$reg2,lr} ; Save The workspace plus the current return ; address lr_ mode into the stack. MEND MACRO RestoreContext $reg1,$reg2 LDMFD sp!,{$reg1-$reg2,pc}^; Return to the instruction following... ; ...the exception interrupt. MEND ;******************************************************************************* ; Exception Handlers ;******************************************************************************* UndefinedHandler SaveContext r0,r3 ; Save the workspace plus the current ; return address lr_ und. ldr r0,=Undefined_Handler ldr lr,=Undefined_Handler_end bx r0 ; Branch to Undefined_Handler. Undefined_Handler_end RestoreContext r0,r3 ; Return to the instruction following... ; ...the undefined instruction. ;******************************************************************************* ;* Function Name : SWIHandler ;* Description : This function is called when SWI instruction executed. ;* Input : none ;* Output : none ;******************************************************************************* SWIHandler SaveContext r0,r3 ; Save the workspace plus the current ; return address lr_ svc. ldr r0,=SWI_Handler ldr lr,=SWI_Handler_end bx r0 ; Branch to SWI_Handler. SWI_Handler_end RestoreContext r0,r3 ; Return to the instruction following... ; ...the SWI instruction. ;******************************************************************************* ;* Function Name : PrefetchAbortHandler ;* Description : This function is called when Prefetch Abort ; exception is entered. ;* Input : none ;* Output : none ;******************************************************************************* PrefetchAbortHandler SUB lr,lr,#4 ; Update the link register. SaveContext r0,r3 ; Save the workspace plus the current ; return address lr_abt. ldr r0,=Prefetch_Handler ldr lr,=Prefetch_Handler_end bx r0 ; Branch to Prefetch_Handler. Prefetch_Handler_end RestoreContext r0,r3 ; Return to the instruction following that... ; ...has generated the prefetch abort exception. ;******************************************************************************* ;* Function Name : DataAbortHandler ;* Description : This function is called when Data Abort ; exception is entered. ;* Input : none ;* Output : none ;******************************************************************************* DataAbortHandler SUB lr,lr,#8 ; Update the link register. SaveContext r0,r3 ; Save the workspace plus the current ; return address lr_ abt. ldr r0,=Abort_Handler ldr lr,=Abort_Handler_end bx r0 ; Branch to Abort_Handler. Abort_Handler_end RestoreContext r0,r3 ; Return to the instruction following that... ; ...has generated the data abort exception. ;******************************************************************************* ;* Function Name : IRQHandler ;* Description : This function is called when IRQ exception is entered. ;* Input : none ;* Output : none ;******************************************************************************* IRQHandler SUB lr,lr ,#4 SaveContext r0,r3 LDR r0, = VectorAddress LDR r0, [r0] ; Read the routine address from VIC0 Vector Address register BLX r0 ; Branch with link to the IRQ handler. RestoreContext r0,r3 LTORG END
Now the big question.
Did you repost your source code, or did you copy the already failed posts and posted once more?
Look for example at:
Do your original source file contains multiple assembler instructions on the same text line?
Notice the button "Preview" that you have to press as first step when posting source code. Did you remember to preview?
Now, you have posted the code twice. And both copies are unreadable.
I'm sorry, I hope now is fine
Debug_Mode EQU 0 (I & F) flags in PSRs Mode_USR EQU 0x10 Mode_FIQ EQU 0x11 Mode_IRQ EQU 0x12 Mode_SVC EQU 0x13 Mode_ABT EQU 0x17 Mode_UND EQU 0x1B Mode_SYS EQU 0x1F I_Bit EQU 0x80 F_Bit EQU 0x40 UND_Stack_Size EQU 0x00000000 SVC_Stack_Size EQU 0x00000008 ABT_Stack_Size EQU 0x00000000 FIQ_Stack_Size EQU 0x00000020 IRQ_Stack_Size EQU 0x00000100 USR_Stack_Size EQU 0x00000400 ISR_Stack_Size EQU (UND_Stack_Size + SVC_Stack_Size + ABT_Stack_Size + \ FIQ_Stack_Size + IRQ_Stack_Size) AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE USR_Stack_Size __initial_sp SPACE ISR_Stack_Size Stack_Top Heap_Size EQU 0x00000200 AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit SCU_BASE_Address EQU 0x5C002000 ; SCU Base Address SCU_SCR0_OFST EQU 0x00000034 ; System Configuration Register 0 Offset FMI_BASE_Address EQU 0x54000000 FMI_BBSR_OFST EQU 0x00000000 FMI_NBBSR_OFST EQU 0x00000004 FMI_BBADR_OFST EQU 0x0000000C FMI_NBBADR_OFST EQU 0x00000010 FMI_CR_OFST EQU 0x00000018 FMI_SETUP EQU 1 FMI_CR_Val EQU 0x00000018 FMI_BBSR_Val EQU 0x00000004 FMI_BBADR_Val EQU 0x00000000 FMI_NBBSR_Val EQU 0x00000002 FMI_NBBADR_Val EQU 0x00080000 FLASH_CFG_Val EQU 0x00000000 PRESERVE8 AREA Init, CODE, READONLY ARM EXPORT Reset_Handler Reset_Handler LDR pc, =NextInst NextInst IF Debug_Mode=1 MOV r0, #0x4000 Loop SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 SUBS r0,r0, #1 BNE Loop ENDIF MRC p15, 0, r0, c1, c0, 0 ORR r0, r0, #0x8 MCR p15, 0, r0, c1, c0, 0 MOV r0, #0x40000 MCR p15,0x1,r0,c15,c1,0 ;------------------------------------------------------------------------------ ; Description : FMI Registers configuration depending on the Flash size selected, ; and the boot bank. ; ; After reset, the application program has to write the size and start ; address of Bank 1 in the FMI_BBSR and FMI_BBADR registers and the size and ; start address of Bank 0 in the FMI_NBBSR and FMI_NBBADR registers. ; ------------------------------------------------------------------------------ LDR R6, =FMI_BASE_Address LDR R7, = FMI_BBSR_Val ; BOOT BANK Size= STR R7, [R6, #FMI_BBSR_OFST] ; (2^BOOT_BANK_Size) * 32KBytes LDR R7, = FMI_NBBSR_Val ; NON BOOT BANK Size = STR R7, [R6, #FMI_NBBSR_OFST] ; (2^NON_BOOT_BANK_Size) * 8KBytes LDR R7, =FMI_BBADR_Val ; BOOT BANK Address MOV R7, R7 ,LSR #0x2 STR R7, [R6, #FMI_BBADR_OFST] LDR R7, =FMI_NBBADR_Val ; BOOT BANK Address MOV R7, R7 ,LSR #0x2 STR R7, [R6, #FMI_NBBADR_OFST] LDR R7, = 0x19 ; Enable Both banks STR R7, [R6, #FMI_CR_OFST] ; --- Enable 96K of RAM & Disable DTCM & AHB wait-states LDR R0, = SCU_BASE_Address LDR R1, = 0x0191 STR R1, [R0, #SCU_SCR0_OFST] ; Setup Stack for each mode LDR R0, =Stack_Top ; Enter Undefined Instruction Mode and set its Stack Pointer MSR CPSR_c, #Mode_UND:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #UND_Stack_Size ; Enter Abort Mode and set its Stack Pointer MSR CPSR_c, #Mode_ABT:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #ABT_Stack_Size ; Enter FIQ Mode and set its Stack Pointer MSR CPSR_c, #Mode_FIQ:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #FIQ_Stack_Size ; Enter IRQ Mode and set its Stack Pointer MSR CPSR_c, #Mode_IRQ:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #IRQ_Stack_Size ; Enter Supervisor Mode and set its Stack Pointer MSR CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit MOV SP, R0 SUB R0, R0, #SVC_Stack_Size ; Enter User Mode and set its Stack Pointer MSR CPSR_c, #Mode_SYS IF :DEF:__MICROLIB EXPORT __initial_sp ELSE MOV SP, R0 SUB SL, SP, #USR_Stack_Size ENDIF ; Enter the C code IMPORT __main B __main IF :DEF:__MICROLIB EXPORT __heap_base EXPORT __heap_limit ELSE ; User Initial Stack & Heap AREA |.text|, CODE, READONLY IMPORT __use_two_region_memory EXPORT __user_initial_stackheap __user_initial_stackheap LDR R0, = Heap_Mem LDR R1, =(Stack_Mem + USR_Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR ENDIF END
VectorAddress EQU 0xFFFFF030 EXPORT Vectors IMPORT Reset_Handler IMPORT Undefined_Handler IMPORT SWI_Handler IMPORT Prefetch_Handler IMPORT Abort_Handler IMPORT FIQ_Handler RESERVE8 AREA Reset, CODE, READONLY ARM Vectors LDR PC, Reset_Addr LDR PC, Undefined_Addr LDR PC, SWI_Addr LDR PC, Prefetch_Addr LDR PC, Abort_Addr NOP LDR PC, IRQ_Addr FIQHandler SUB lr,lr,#4 STMFD sp!,{r0-r3,lr} ldr r0,=FIQ_Handler ldr lr,=FIQ_Handler_end bx r0 FIQ_Handler_end LDMFD sp!,{r0-r3,pc}^ ;******************************************************************************* ; Exception handlers address table ;******************************************************************************* Reset_Addr DCD Reset_Handler Undefined_Addr DCD UndefinedHandler SWI_Addr DCD SWIHandler Prefetch_Addr DCD PrefetchAbortHandler Abort_Addr DCD DataAbortHandler DCD 0 IRQ_Addr DCD IRQHandler MACRO SaveContext $reg1,$reg2 STMFD sp!,{$reg1-$reg2,lr} MEND MACRO RestoreContext $reg1,$reg2 LDMFD sp!,{$reg1-$reg2,pc}^ MEND ;******************************************************************************* ; Exception Handlers ;******************************************************************************* UndefinedHandler SaveContext r0,r3 ldr r0,=Undefined_Handler ldr lr,=Undefined_Handler_end bx r0 Undefined_Handler_end RestoreContext r0,r3 ;******************************************************************************* ;* Function Name : SWIHandler ;* Description : This function is called when SWI instruction executed. ;* Input : none ;* Output : none ;******************************************************************************* SWIHandler SaveContext r0,r3 ldr r0,=SWI_Handler ldr lr,=SWI_Handler_end bx r0 SWI_Handler_end RestoreContextr0,r3 ;******************************************************************************* ;* Function Name : PrefetchAbortHandler ;* Description : This function is called when Prefetch Abort ; exception is entered. ;* Input : none ;* Output : none ;******************************************************************************* PrefetchAbortHandler SUB lr,lr,#4 SaveContext r0,r3 ldr r0,=Prefetch_Handler ldr lr,=Prefetch_Handler_end bx r0 Prefetch_Handler_end RestoreContext r0,r3 ;******************************************************************************* ;* Function Name : DataAbortHandler ;* Description : This function is called when Data Abort ; exception is entered. ;* Input : none ;* Output : none ;******************************************************************************* DataAbortHandler SUB lr,lr,#8 SaveContext r0,r3 ldr r0,=Abort_Handler ldr lr,=Abort_Handler_end bx r0 Abort_Handler_end RestoreContext r0,r3 ;******************************************************************************* ;* Function Name : IRQHandler ;* Description : This function is called when IRQ exception is entered. ;* Input : none ;* Output : none ;******************************************************************************* IRQHandler SUB lr,lr ,#4 SaveContext r0,r3 LDR r0, = VectorAddress LDR r0, [r0] BLX r0 RestoreContext r0,r3 LTORG END
