Hi Guys,
I'm writing my own TCP/IP Stack. I've got following structure:
typedef struct __attribute__ ((packed)) { uint16_t type : 16; uint16_t protocol : 16; unsigned char hw_size : 8; unsigned char prot_size : 8; uint16_t op : 16; uint64_t srcMac : 48; uint32_t srcIP : 32; uint64_t dstMac : 48; uint32_t dstIP : 32; } ARP_Header;
If i want to compare the protocol value, the comparison isn't true, altough there is the right value in it.
if(rx_arp_header->protocol != ARP_PROT_Type_IP) { DEBUG("Protocoll Error: %x\n", rx_arp_header->protocol); return; }
ARP_PROT_Type_IP is defined by: #define ARP_PROT_Type_IP SWAP16(0x0800)
And SWAP16:
#define SWAP16(x) ((x & 0x00FF) << 8) | \ ((x & 0xFF00) >> 8)
I have found a workaround: I have to cast the SWAP16 value to an integer. Why? The code size is increasing about 200 Bytes.
Can you help me?
br Robert
> If i want to compare the protocol value, the > comparison isn't true, altough there is the right > value in it.
Did you mean to say is always true? That is what I get.
> I have found a workaround: I have to cast the SWAP16 > value to an integer. Why?
Perhaps it fixed the parentheses issue? You can't have enough parentheses in macros.
Because the compiler actually generated code for evaluating the condition in all cases where this macro has been used.
Regards Marcus http://www.doulos.com/arm/
Hi, the problem is the SWAP16 macro. The source code will be converted to
if(rx_arp_header->protocol != SWAP16(0x0800))
and then to
if(rx_arp_header->protocol != ((0x0800 & 0x00FF) << 8) | \ ((0x0800 & 0xFF00) >> 8)
As you may see, the SWAP16 must be in additional parentheses, otherwise, its always true
rx_arp_header->protocol != ((0x0800 & 0x00FF) << 8) // gives true or false | ((0x0800 & 0xFF00) // always gives true
Change the define to:
#define SWAP16(x) (((x & 0x00FF) << 8) | \ ((x & 0xFF00) >> 8))
