Hi all, How can I have .elf output file in uVision (and not .axf!)? Regards, Reza
Assuming it is an elf file generated by Gnu/CodeSourcery tools, simply load it using the 'LOAD' command or by specifiying the load command as part of a .ini script file...
Do you already have an ELF file that you want to load into the uVision debugger/simulator?
Or do you want to generate an ELF file as the result of your build?
I want to generate an ELF file as the result of build process.
Please Help!!
Reza; You do know that you are not discussing your problem with Keil support don't you? We are just users like you. I do not have an answer to your problem but I suggest that you contact Keil Tech Support directly. I do know that the GNU tools will output an ELF file but I do not know of a way to make MDK output and ELF. Bradford
objcopy
OK I contact to support, but I thought it must be so simple (As simple as "selecting a format from a menu" because uVision is as user friendly as other tool-chains like I*R E*ARM).
Mdk generates .axf files, a .axf file is a elf/dwarf file !
