I am using ATMEL SAM 9263 as my target and ATMEL SAM ICE with JTAG interface as the debugger. While using the KEIl IDE, under "Options for Target 'sram-SAM-ICE'", below the "debug" tab, I am selecting an initialistion file JLinkArm_sram-SAM-ICE.ini, which has the following commands
FLASH SkipProgOnCRCMatch = 1 VerifyDownload = 1 AllowCaching = 1 EnableFlashDL = 2 Override = 0 Device="ADUC7020X62" [BREAKPOINTS] ShowInfoWin = 1 EnableFlashBP = 2 [CPU] AllowSimulation = 1
While attaching the device from KEIL IDE, I am getting an error for these commands. Since I wish to execute my program from SRAM, should I need different commands for SRAM. Can anybody please help me with the commands.
Hmmm ...
all the settings should be set up proper when you select the correct device from the Options for Target - Menue.
Also the device in your command list is wrong, and the SAM-ICE will _never_ work with a device that does not come from Atmel.
Try this minimal example:
load Int_RAM\Blinky.axf PC = 0xF8002000 g, main
Of course you have to set the value for the PC to where your programm starts in SRAM, and the name/location of your axf file :-)
Also you can find an example where the SRAM is set up from the debugger (when entering debug session), this is located in: C:\Keil\ARM\Boards\Atmel\AT91SAM9263-EK\Blinky
BR, /th.
