I have a problem that I have to urgently solve. I am using LPC3250. I want to handle the IRQ interrupt for the receive data. I mean, when data comes to the receive fifos, I want to get an IRQ interrupt and handle the tasks.
I wrote the following codes to enable the interrupt:
MIC_ER = 0x200; // enable uart5 interrupts UNIER = 0x01; // enable receive data available interrupt. UNFCR = 0x06; // reset the transmit and receive fifos UNLCR = 0x00; // Reset DLAB to 0.
However, when I proceed in main, the code suddenly goes to the irq handler, although no data comes to fifo. In continuously takes irq interrupt and never stops at all. What may be the problem? Am I doing anything wrong in enabling bits?
I'll be very glad to hear from you. Thanks for your helps..
Have you read out the status register and checked which bits are set? They tell you the reason(s) for the interrupt.
Hi, I read the status bits. The 8th bit is set, which is the interrupt that I enable.
The main problem is that; the program constantly goes into the irq interrupt, although I disable all the interrupts other than UART5 receive.
Can anyone please tell me the required register enabling?
Thanks..
I mean the 9th bit is set, not the 8th bit.
Not sure what register you read.
You shouldn't look at the register that tells what interrupts are current pending.
If you get a UART interrupt, you should look at the UART register that identifies which tasks the UART needs serviced. Such as read data available, transmit buffer empty, receive overrun, auto-baud finished, ...
If you don't look at these bits and service pending requests, you will normally get a new interrupt as soon as the ISR ends.
I am reading the "Interrupt Identification Register, IIR". The 0th bit should be 0 for interrupt pending, but it is always 1, which shows there is no interrupt.
Also, after reading that register, the program keeps going to the irq state over and over again.
I am really stucked.. Could you show me the correct register enabling, maybe I have a problem there.
After reading the 0th bit, if it is "0", then the next 3 bits shows the interrupt address. But the next bits are all "0"s, so I cant find any source of interrupt.
If bit 0 is 0, then the following 3 bits are defined.
And if they are 0, that means that you have a modem status interrupt. The datasheet says that you should read the MSR.
Unfortunately the 0th bit of U5IIR is not "0", it is always "1".
Are you sure you haven't mapped multiple interrupts to the same ISR?
All the interrupts other than the "Receive Data Available Interrupt" of UART5 are disabled as seen below.
The PC directly goes to the ISR, it doesnt go to the interrupt vector table first.
do other interrupt sources exhibit the same behavior? try to interrupt the processor by a timer, for instance. what happens?
I solved the continuous interrup problem. Now, there is another problem.
When I send data to the receive fifo, the interrupt comes. in the ISR, i check the U5IIR register, i hope to find 0x0100, but there is 0x0001, which means there is no interrupt.
The interrupt occurs at the right time, but I cannot see the occurance from the register.
What can be the reason for this?
Please start off by telling what the cause was for the previous problem.
Suprisingly I wrote U5IER = 0x01 above MIC_ER = 0x200, and the continuous interrupt problem was solved.
Now, I can get the interrupt when data is received. But, in the ISR, I have the following:
MIC_SR = 0x200 ; it means there is interrupt from UART5, which is good! U5IIR = 0x01 ; it means there is no interrupt seen in the UART5, which is not good at all. I expect to see U5IIR = 0x04, but I just cannot.
Is there a way to initialize the IIR register, or do I need to do anything else?
Have you verified that the header file is good, so you really are reading the correct register?
