EMAC Receive Problem
DWORD EMACReceive( DWORD *EMACBuf )
  DWORD RxProduceIndex, RxConsumeIndex;
  DWORD RxLength = 0;
  DWORD Counter = 0;
  /* the input parameter, EMCBuf, needs to be word aligned */
  RxProduceIndex = MAC_RXPRODUCEINDEX;
  RxConsumeIndex = MAC_RXCONSUMEINDEX;
  if ( RxProduceIndex == EMAC_RX_DESCRIPTOR_COUNT )
        /* reach the limit, that probably should never happen */
        MAC_RXPRODUCEINDEX = 0;
        CurrentRxPtr = EMAC_RX_BUFFER_ADDR;
  /* a packet has arrived. */
  if ( RxProduceIndex != RxConsumeIndex )
        if ( RxProduceIndex < RxConsumeIndex )       /* Wrapped around already */
          /* take care of unwrapped, RxConsumeIndex to EMAC_RX_DESCERIPTOR_COUNT */
          RxLength += EMACReceiveFractions( RxConsumeIndex, EMAC_RX_DESCRIPTOR_COUNT );
          Counter++;
          PacketReceived = TRUE;
          /* then take care of wrapped, 0 to RxProduceIndex */
          if ( RxProduceIndex > 0 )
                RxLength += EMACReceiveFractions( 0, RxProduceIndex );
                Counter++;
        else                                    /* Normal process */
            RxLength += EMACReceiveFractions( RxConsumeIndex, RxProduceIndex );
                Counter++;
  return( RxLength );
This is my EMACReceive function and
#define MAC_RXPRODUCEINDEX  (*(volatile unsigned long *)(MAC_BASE_ADDR + 0x114)) /* Rx produce index reg (RO) */
#define MAC_RXCONSUMEINDEX  (*(volatile unsigned long *)(MAC_BASE_ADDR + 0x118)) /* Rx consume index reg */
Execution skip the receiving portion bescause RxProduceIndex = RxConsumeIndex = 0
What wil be the problem
Thank you
