I am using ucos+uctcp/ip to learn now.
I want a stack of ucos task such as
#define WEB_TASK_SIZE 800 static OS_STK webTaskStk [WEB_TASK_SIZE];
or other array be placed in usb SRAM , how can i define two exe region in the scatter file?
Its a scatter file for lpc2378 in keil IDE below:
;****************************************************************************** ; ; SCATTER LOADING DESCRIPTION ; ARM ; KEIL's uVision3 ; (RealView Microprocessor Developer Kit) ; ; Filename : LPC2378_Flash.scat ;****************************************************************************** LR_IROM1 0x00000000 0x00080000 ;; Load region { ER_IROM1 0x00000000 0x00080000 { vectors.o (VECT, +First) init.o (INIT) * (+RO) } RW_IRAM1 0x40000000 0x0000e800 { * (+RW,+ZI) } ;; The following declarations select the "two region model" ; ;; A default __user_initial_stackheap() will be used ; ARM_LIB_HEAP 0x40007000 EMPTY 0x00000100 {} ARM_LIB_STACK 0x40008000 EMPTY -0x00000E00 {} }
I want the 32 kb ram of lpc2378 be the first exe region,and the 10kb usb sram be the second exe region.
pls hlp me.
I am sorry my bad English.
I had post a question message , then so many friends post answer message to hlp me ,,I thanks them very much.
Best Regards, Derek
and anybody have a web url about "ucos" or "uctcp/ip" study?
pls share me a web url about "ucos",or "mcb2300",or "uctcp/ip" to study or use ,,
Thks!!
Derek
