Hello everyone i am new to microcontroller programming. I am doing a project using LPC1768. To learn about spi i used a debug feature of debugger. I wrote the follwing program for spi simulation.
#include <LPC17xx.H> int main(void) { SystemInit(); LPC_SC->PCONP |= 0x00000100; //LPC_SC->PCLKSEL0 |= 0x00200000; LPC_GPIO0->FIODIR |= 0x00010000; LPC_GPIO0->FIOSET |= 0x00010000; LPC_PINCON->PINSEL0 &= 0xC0000000; LPC_PINCON->PINSEL1 &= 0xC000003F; LPC_SPI->SPCR = 0x38; LPC_SPI->SPCCR = 0x08; while(1) { LPC_SPI->SPDR = 0x01; while(!(LPC_SPI->SPSR & 0x80)); } }
in simulation after LPC_SPI->SPDR = 0x01; i am expecting content of SPDR register to be 01.But in simulation SPI dialog box it is showing 00. SPIF bit set to be 1. In the logic analyzer SPI_OUT is always 0.
Thanks in advance.
Regards
The first write to SPDR goes directly to serial shifter so you do not see it in SPDR. After some time you should see SPI_OUT to change.
I guess you do not have clocks setup or enabled correctly.
Thanks for your reply. i found the problem. As u rightly pointed out the problem was with the settings. i have some questions first is that SPDR register value never changes why is that? second what is spi_out? is this signal same as MOSI? thanks again for ur reply
regards
